Bumpstop Mod: my first try at writing an install
so i pulled the green tab out and its hitting now. thanks for that write up. The Best V8 Stories One Small Block at Time
if you look right in front of the battery there a small black half cylinder looking thing with 3 wires running to it i believe its your cruise control. Pop the top and you will see the wire house on the very bottom theres a small piece of green rubber like a bump stomp that prevents you from going WOT just take a flat head and pop that little sucker out of there now you can go WOT as far as the bumpstop on the TB will allow
!!! Hope this helps you out Alt and any others that have this problem Sorry i dont have any pics to post but if you just look you will find it...
I don't use the traction control anyway, the first thing I do when I get into the car is disable it. But will it still work after taking that green rubber out?
Any idea what its purpose was?
