Bumpstop Mod: my first try at writing an install
Old May 6, 2009 | 10:10 PM
  #101
Firefighterformula's Avatar
Glad somebody brought this back from the dead...hadn't noticed it before.
Wonder why no sticky? Any of you guys who have done this lately notice a difference?
Old May 8, 2009 | 09:01 PM
  #102
andy670ho's Avatar
Put it in your favorites it will always be there!
Old May 8, 2009 | 09:30 PM
  #103
SMOKNSS's Avatar
Definately good mod! Should be a sticky for the new guys.
Old Aug 5, 2009 | 11:56 AM
  #104
thatguy383's Avatar
So would just removing the "green rubber stop" only help some...?
Old Dec 22, 2009 | 02:14 PM
  #105
$750 L98's Avatar
Going to do this mod on a 1989 Formula 350 with a motor swap. This should be a good testament to the mod as I believe I have a severe case of bump stop issues. Sometimes WOT is not even accessible, preventing kick down and 100% throttle fuel/spark.
Old Dec 22, 2009 | 09:56 PM
  #106
$750 L98's Avatar
Fixed my issue:
Throttle Cable was too long.
Pushing the pedal to the floor showed 3.8-3.9v on the TPS.
Manually pulling back throttle only showed 4.3v before hitting bump stop.
Fix:
Shortened throttle cable.
Ground bump stop until reaching 4.65v.
Results:
The car bounces to the rev limiter if I blip the throttle.
No gear has any traction from a roll or 70mph punch.
Throttle response in an situation is VASTLY improved.
Old Dec 30, 2009 | 04:34 PM
  #107
djfury05's Avatar
when I did it the blade would open .02 more when I used the gas pedal, vice using my hand. I even tried it with that little green rubber piece removed. I removed it and got a reading of .70 before turning the blade.. when the piece was still installed the reading was .55.. So I put it back in. I'm at 4.61 and need some more stones to finish it off.. Good free mod.. SOTP can definitely feel a difference. But I also must say I did the free ram air mod too at the same time.
Old Dec 31, 2009 | 03:04 PM
  #108
djfury05's Avatar
I finally completed mine and its 4.52 with the gas pedal and a idle reading of .55 with the green rubber piece still inserted ... when I had the blade opened to 4.66 using the gas pedal.. the idle reading was .57 with the throttle cable adjusted.. .55 to .57 caused my car to idle at 1200, vice 800, which is normal for me. So I adjusted the throttle cable back to .55 and its 4.52.. Before starting was 4.25.. so I still made a gain
Old Feb 2, 2010 | 08:37 PM
  #109
1Bad97WS-6's Avatar
I now this is a old thread.How hard is it to take the green rubber tab out did it help any or should I live it in.Will it efect the traction control..Iam doing a P&P TB also. Iam trying to get all the performace out of this car..
Old Feb 3, 2010 | 09:42 AM
  #110
WizardofDetailing's Avatar
Wasn't sure about this free mod til I read this write up on it. Made it much easier to understand exactly what to do and what not to do. Thanks, will have to ad this on my next garage day.
Old Feb 3, 2010 | 12:13 PM
  #111
zacht's Avatar
id like to see dyno and track numbers, improvements....
Old Feb 16, 2010 | 11:06 PM
  #112
1Bad97WS-6's Avatar
Soon as the tracks open I will get a track numbers for you..
Old Mar 19, 2010 | 04:28 PM
  #113
bill12690's Avatar
once again, old thread i know..
the gasket between the TB and intake manifold is rubber and can be re-used right? I'd like to take my TB off and clean it while im doing this, and just want to make sure I wont have to buy a new gasket first. and if it is rubber, do they have a habit of cracking? Thanks guys
Old Mar 19, 2010 | 05:14 PM
  #114
9t8z28's Avatar
No, it should be fine. They are reusable. Just take a good look at it.
Old Mar 19, 2010 | 07:00 PM
  #115
bill12690's Avatar
sweet thanks..
Old Nov 30, 2010 | 09:23 PM
  #116
DeLaRosa25's Avatar
I know a dremel was used in the write up, but what bit to do bump stop?
Old Nov 30, 2010 | 09:46 PM
  #117
bayer-z28's Avatar
Very nice work bro..
Old Nov 30, 2010 | 10:52 PM
  #118
masterz28's Avatar
yes remove the green rubber gromet to get the throttle blade to open up all the way.
Old Dec 1, 2010 | 01:29 PM
  #119
HAZ-Matt's Avatar
For grinding metal my favorite bits are either the tungsten carbide cutter or one of the sanding drums. They make aluminum oxide grinding bits which are supposed to be for something like this though. There isn't too much difference because the abrasive on their sanding bands are aluminum oxide as well AFAIK.
Old Mar 18, 2014 | 05:55 PM
  #120
Airborn334's Avatar
Default sorry for bringing up a dead thread..
Im new to fbodies as I got my first one about a month ago, 2001 ws6 a4. So being behind the powercurve, im finding these threads for the first time. I attached two photos, the photo registering .559 is my idle reading and the 4.43 is my wot (foot to the floor reads 4.45, not a big difference). Should my idle be that low? The car seems to idle fine. Will adjusting .20-.22 make a noticable difference?
Attached Thumbnails Bumpstop Mod: my first try at writing an install-20140318_183013.jpg   Bumpstop Mod: my first try at writing an install-20140318_183033.jpg
