ramps to install headers?
Old Jan 8, 2006 | 11:55 AM
Rothman's Avatar
Default ramps to install headers?
I would like to do my header install in my garage, but was wondering if I get ramps will that be high enough? What is the best way to get it high enough without a lift?
Old Jan 8, 2006 | 12:04 PM
vodas00ss's Avatar
no way, your gonna need about 12-15 inches clearance under the tires to slide some long tubes up in there. I had to use a full size floor jack, and some blocks of wood to jack it up high enough, then set it on some larger 3 ton jack stands. I raised all 4 corners up, dont know if that is a must do, but it sure did make it easier for me.
Old Jan 8, 2006 | 12:08 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
^ Yup.
I used ramps under the rear tires, one huge jack under the K-member and a 4X4 block of wood between the jack and the K-member. And a handful of jacks for safety.
Old Jan 8, 2006 | 12:10 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Ramps worked just fine for me, but then again I was installing mids. Looks like you're going to do LTs. Probably would need a decent amount more room for those.
Old Jan 8, 2006 | 12:11 PM
vodas00ss's Avatar
Originally Posted by SouthFL.02.SS
^ Yup.
Ya i ran the rear up on ramps first then jacked up the front put it on stands then put the rear on stands.
Old Jan 8, 2006 | 12:13 PM
bolton98TA's Avatar
i didnt bother with the back, i just ran the from up on ramps then jacked it up just a little more (to unload the suspension) and i had pelnty of room to get me pacesetters up in their.
Old Jan 8, 2006 | 12:41 PM
Danny2tek's Avatar
Same here
Old Jan 8, 2006 | 01:16 PM
Rothman's Avatar
well looks like I need a bigger jack and some ramps then! Any idea about how high the wheels should be off the ground? I'm installing pacesetters.
Old Jan 8, 2006 | 01:22 PM
THE CHOP SHOP's Avatar
When i did my pacesetters I measured 12 inches from the bottom of the wheel to the ground in the front. It was just the right amount to get them up there comfortably. I was scared about getting it that high but it was not that bad just take your time and use some extra stands for back ups if you got them.
Old Jan 8, 2006 | 01:26 PM
Rothman's Avatar
awesome thanks.
Lithium's Avatar
SSU's Drunk Typing Whore
Yeah you wont know for sure till you get it jacked up and try to get them in there. I had my jack pretty much maxed out until I could slide them in there. I never needed to use wood to get it higher either.
Old Jan 8, 2006 | 03:07 PM
Rothman's Avatar
yeah but my jack is a $15 wal mart jack!!!
Old Jan 8, 2006 | 03:20 PM
Lithium's Avatar
LOL you feel safe under a 15$ jack?
Old Jan 8, 2006 | 05:08 PM
bolton98TA's Avatar
haha, do you have a sams club around where you live? if so i got my rousch 3ton floor jack there for 75$, verry nice jack for the money.
Old Jan 8, 2006 | 06:41 PM
Yeah i second the sam's that is what i used except i have the goodyear one they sold like last year. I also have stands similar to the ones they sell. I felt fine going under the car and when i tried to give it a push it felt real secure up on all fours with twelve inches in the front.
Old Jan 8, 2006 | 06:52 PM
Rothman's Avatar
Believe me I'm scared every time I head under the car using that thing! Fortunately I also have $15 dollar jackstands. I figure those are worth a little if the jack gives out. Even though their chincy too.
Old Jan 8, 2006 | 10:36 PM
Transgression's Avatar
i'll be installing pacesetters soon too....would 2 cinder blocks under each wheel(4total) be good enough for LT install?
Old Jan 9, 2006 | 08:22 AM
weestro's Avatar
I put the rear on ramps and put a 4x4 block on my 4-ton AC hydraulic fully entended under the k-member. When you have the front high enough, you'll need a ladder to get into the engine bay.
