ls1 poly motor mounts
the stock ones dont last and they let the engine move way too much
if you have a 6 speed they will keep your exhaust from banging and the gear stick from jumping when you are snatching on the car
Once you get the old ones out you have to use a 3/8 bit to drill out the rivits holding the metal pieces together. Put the poly mount in, and use the supplied bolts to secure the metal pieces together again. Its easy to do but getting them out and back in can be a royal PIA! Expect to take ~4 hours if all goes smoothly.
BTW, you might as well do a poly tranny mount while you are at it. Its only another $23 and takes about 25 mins to do.
also, im about to do the motor mounts also!
