corvette heated O2 sensors
Old Jan 12, 2006 | 09:43 AM
badmfkr's Avatar
Default corvette heated O 2 sensors
I think I may be due for new front O2 sensors the slites in the rears looked like they where closed up with carbon deposits, haven't inspected the fronts but am thinking they can't look any better than the rears.
was told to get the Corvette type with longer wires an ilimanate the O2 extentions .
which year & model of vette do I get?
my car has 70K miles
Thanks for the advice
Old Jan 12, 2006 | 08:48 PM
WhiteRhino's Avatar
Bosche part #13111
Old Jan 13, 2006 | 09:22 AM
badmfkr's Avatar
I was told Bosche is not recommended I would prefer AC delco.
Thanks
Old Jan 13, 2006 | 09:40 AM
renips's Avatar
Thanks
OEM 25317697
Old Jan 14, 2006 | 12:01 AM
THE_SUPRA's Avatar
ac/delco blows IMO
Old Jan 14, 2006 | 12:23 AM
Rescue Ranger's Avatar
Originally Posted by THE_SUPRA
ac/delco blows IMO
Why do u think ac/delco blows? some people think they're all that some dont. Don't they outsource their parts, and thus really not a GM authentic part at all? In that case i'd definately agree.. just curious to hear your reasoning.
Old Jan 14, 2006 | 10:15 AM
bowtieman81's Avatar
Bosch 13111 here, no probs. You will get varied opinions on O2 sensors. Some like Bosch, some Denso, some GM. You can check in the PCM diagnostics forum and there are several threads on it.
I got the Bosch and they work fine for me. They switch quickly and the wires were plenty long to reach my LT headers.
Old Jan 14, 2006 | 11:22 AM
jimmyblue's Avatar
Moderator
Last I looked, all O2 sensors were manufactured by either
Bosch or NGK / NTK. Don't know whose is under the GM
brand.
Old Jan 14, 2006 | 11:33 AM
badmfkr's Avatar
the orginal O2 sensors have AC delco stamped on them.
was told to get the Corvette type with longer wires an ilimanate the O2 extentions . an expert tuner told me that when using O2 extensions it's not a solid connection and slows the process down.
Thanks guy's for the Bosh PN. but preferr orginal AC
Old Jan 14, 2006 | 12:12 PM
SSpdDmon's Avatar
Check the 3rd post down...
p/n 25317697
If you need a year, 2002 will work. They're all the same (convertible, fast-back, Z06).
Old Jan 14, 2006 | 12:16 PM
badmfkr's Avatar
thanks third post down I' assumming this is the vette O2
Old Jan 14, 2006 | 12:20 PM
MeentSS02's Avatar
Kleeborp the Moderator™
With LT headers, it is only a matter of time before any O2 sensor starts giving you issues. You'll just have to trust me on this one...been down this road before.
Old Jan 25, 2006 | 01:12 AM
LS1MONSTER's Avatar
Damn I just checked the price on the Vette 02's.. 126.63. Wowzers. That is from SDPC. Anyone know if they can be had for cheaper?
Old Jan 25, 2006 | 01:37 AM
LS1MONSTER's Avatar
Okay I just checked on GMpartsdirect...112.00 bucks each. Not too bad.
Old Jan 25, 2006 | 09:19 AM
badmfkr's Avatar
Default Steve
nice ride I dig the rims, looking forward to meeting you next time I'm in the area. I plan on preamently relocating down there. soon.
Stephen
Old May 11, 2006 | 04:47 PM
badmfkr's Avatar
Default corvette O2 sensors 13111 aren't these only for the back
Planning on new O 2 heated oxogen sensors for a LTs car.
can the fronts be used on the back & vis versa?
parts man told me the vette o2 PN 13111 was for the back?
Thanks
Old May 11, 2006 | 05:21 PM
2K2WS6TA's Avatar
Thanks
That's what you want the rear heated o2 sensors from a C5 Corvette (I used 2002 as the model year when I ordered mine) I got the bosch p/n 13111
For the rears either use 02 simms, or have them tuned out with HPTuners/EFILive
If you want to know where to get the o2 sensors cheaper than $112 each PM me
Old May 11, 2006 | 07:03 PM
badmfkr's Avatar
Default O2 sensors
Ok sounds like the 13111 will be used then I can unload the wire extentions and maybe the car will run a bit better (without the extentions)?
I checked into O2 about 5 months ago the slites appeared to be getting clogged with carbon first place I checked LS1speed $100. each 2nd spdc $120. each
I'm getting suspisious of the stuff they have at discount auto there price $74.
each
Thanks
Old May 11, 2006 | 07:33 PM
2K2WS6TA's Avatar
Well mine were genuine bosch o2s, came in a bosch box, say bosch on the side, so AFAIK they are bosch sensors
Old May 14, 2006 | 09:26 AM
badmfkr's Avatar
Default O2 sensors
OK got the Bosh 13111 at napa paid $73. each. I did smell something burning thinking this was the newness of sensor smell dissappeared in about 2 hours.
glad to see the peskie SES go off. after 2 days (just did regular driving did'nt do the driving procedure.
My ?s are
1.did I get a cheap disscounted verision of the real bosh 13111?
2. how long can I expect these to last Steve meents mentioned expect to replace more often with LTs?
3.thoughts on half the # of slites in sensor prob. compared to stock O2?
4. I'm thinking the bad O2 caused the peskie Po300 misfire?
5. will I notice a preformace improvement without the extentions?
6. which color wire should I use to connect the air/fuel ratio meter up to?
7. is it normal for both fronts to bad at same time?
Thanks
