Run Straight LT's?
I would like to know, for a car that will see very little street time and mostly strip, is it safe to run Straight Pacesetter Longtube headers? Will there be any problems w/ the Front O2 sensors?
If need be what size/diameter pipe should i use for the Pacesetter merge collector?
Whats the big deal on getting some scrap pipe from an exhaust shop and clamping it on there? You seem dead set against it.
What we are saying, is the best tune in the world would likley be SCREWED by the fact that the O2's wont be able to read as well as they should. You will need some 3" pipe, probably have to get them to stick it in the expander as well so it will slip over a piece of 3" pipe. You can rent a pipe expander from autozone i think.
It can be done.
It can be done.
Basically, closed-loop works kinda like this...there's a grid of fuel trims (cells) that represent different driving conditions (low rpm/low load, high rpm/med. load, WOT, idle, etc.). The percentage the PCM increases/decreases the trims for the conditions is determined by the front O2 feedback. For example...
Let's say the PCM is commanding an average AFR of 14.63...and based on the feedback from the O2's, it finds your AFR is really 15.0. So, the PCM then says, "If 15.0/14.63=1.0253, then increase (because I'm lean) the fuel trim cell for this driving condition by 2.53%."
This is done over a hundred times each minute and called short term fuel trims (STFT). The average of the STFT's is recorded for each condition and becomes a long term fuel trim (LTFT) if it is consistently rich or lean. The tricky thing about LTFT's is when you transition to WOT (open-loop) and you have negative LTFT's, it will not subtract any fuel. But if you have positive LTFT's, it will add them to it's fueling calculation. This is because the PCM is guessing the AFR in open-loop. So, it's saying if I'm lean in several conditions during closed-loop, I need to assume a lean condition at WOT (open-loop) whether it's lean or not.
Make sense?
-Joel
Now for my question does the Pipe have to be welded or can it be slip fitted w/ a clamp of some sort to the headers?
-Joel
