Coil Pack Re-Location Kit
Old Jan 15, 2006 | 01:37 PM
DAPSUPRSLO's Avatar
Default Coil Pack Re-Location Kit
Guys, what kits have you used and what do you like/dislike about them. They will be used on a car which has the cowl removed for my sb2 intake on a motor with c5-r heads. Thanks.
Old Jan 15, 2006 | 01:43 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
There are a few that a really pricey. I think most of the kits come with all wires and everything. I love the way it cleans up the engine compartment a little more. If you have fancy looking valve covers they would look even better in my opinion.
Old Jan 15, 2006 | 04:41 PM
akZ28's Avatar
Waste of time and money.
Old Jan 15, 2006 | 07:16 PM
DAPSUPRSLO's Avatar
Well in my case this will be needed as my c5-r valve covers do not have mounting provisions. Nor, in my opinion, do the big nasty coil packs do anything for visuals on the valve covers. Thanks.
Old Jan 15, 2006 | 09:00 PM
LawmanSS's Avatar
I suppose it's all a matter of what your priorities are...for me, I liked the cleaner appearance and my aftermarket covers didn't have coil mounting provisions, so it wasn't a waste of time or money. I went with the Thunder Racing kit...the only change I made was to swap out the included hardware for stainless pieces...I highly recommend this kit...
Old Jan 16, 2006 | 08:01 AM
DAPSUPRSLO's Avatar
Thanks
Old Jan 16, 2006 | 08:08 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Oh, and for the record...Lawman. Your engine bay looks bad ***!
Old Jan 16, 2006 | 08:32 PM
LawmanSS's Avatar
Thank you!
Old Jan 16, 2006 | 09:08 PM
BNKBRKR's Avatar
LawmanSS, u got a pic of your engine bay? I was thinking about this myself.
Old Jan 17, 2006 | 08:59 AM
~JOSHUA's Avatar
I made my own kit. Kind of like the Thunder Racing kit but mine is polished aluminum. If you under the cowl you can see them back by the firewall. Here's some pics for the guy that wanted some...
Old Jan 17, 2006 | 02:46 PM
LawmanSS's Avatar
Sorry, these are crappy pics...it's hard to see the coil relocation, but if you concentrate , you can see the coil packs under the cowl:
Old Jan 17, 2006 | 02:52 PM
mellowyellow's Avatar
awesome....
Old Jan 17, 2006 | 02:53 PM
1CAMWNDR's Avatar
Go to Lowe's and get yourself 3 feet of threaded rod. Get 8 nylon lock nuts to match. Get some rubber fuel line to seperate the coils. String the coils on the rod seperated by rubber fuel line. Install nuts up to outside coils. Measure 1.5" away and put a second nut. Cut rod. Repeat for other side. Drill 4 holes in plastic part of cowl. Run zip tie through holes and loop between the 2 end nuts on the rod. Costs about $12.00 in parts.
Let me find a few pics of mine:
