Kooks installers come in.
I left the plugs in, and No you dont have to touch the alternator...
The drivers side has to go Straight up, make sure your car is off the ground far enough
Oh, and save yourself TONS of hassle and get a set of metric Gear Wrenches. You'll thank me when getting to all the header bolts..
So all the plugs are out exhaust manifolds are off coil packs are off and the dip stick tube is out.
Disconnect the battery you never know where wrenches might go or bolts.
The passanger side i put right up from the bottom nothing else needed to be removed.
Then remvoe the oil filter(DO NOT REUSE THE OLD FILTER).
Dissconnet the tranny mount. i took the whole trans mount down and off the car. This gives you extra "twist" when jacking the motor.
I then removed the alternator leaving it in its place but removeing all the bolts so i could get the motor mount bolt out.
Take out the motor mount bolt now on the driver side. Use a jack(with a peice of wood on it) to help ease the bolt out and silicone is also your firend here.
Once you get that out remove the steering shaft there are 2 7/16 bolts that hold it in.
Also Take the WHOLE motor mount bracket if you would like to call it out. It is bolted to the subframe. They are 4 15mm bolts.
After those were out the header went right in from the bottom.
So quick list
-stock manifolds
-stock y pipe
-coil packs
-plugs
-dip stick
-steering shaft
-motor mount
-oil filter
-Trans mount
Hope this helps If i would of disconnect the trans mount ALL THE WAY not just the center bolt i woulda been less stressed at the end. Then i finally relized i need more twist on the motor and that was what was holding it up.
Kyle
I have 1-7/8" kooks and if you have your car jacked up high enough you can slide them in from the bottom.. as long as the steering shaft is out..
And when i mean high enough.. you may have to get creative.. I had to use a large block of wood on my jack (my jack and jack stands weren't tall enough alone).. Get inventive but BE SAFE!!!!!
Well, one you might have to go under the car to reach better but you get the idea.
Oh, and DONT turn the shaft during disasemmbly or after.
Chris
I DIDN'T have to take off the coil packs, steering shaft, oil filter, spark plugs, or alternator. I also didn't loosen the motor mounts or tranny mount.
I did take off the plug wires and dipstick.
The passenger side slid right in and the driver's side slid in after I found the right angle.
For ease, we remove the coil packs to remove the plugs/wires (Usually changing the plugs when doing a header install and easier to get headers in w/o worrying about breaking plugs). Remove the dipstick. Remove the stock exh/cats/y-pipe. Both side headers go right into place. The driver's side hold vertically (#1 cylinder tube towards the sky) and it slides right in. We have done these installs on jack stands and lifts, not a problem usually 3-4 hours with our y-pipe modifications.
- Matt
...O you better put polly-motor mount's in now or you will get Y pipe BANG
