!air...
1.) The electronic sensor to the air pump... where's it go now? Can it just be routed back to the source and removed? (I didn't look and see where the source was.)
2.) I bought block off plates from LS1speed and they fit fine but I'm wondering if it's supposed to smell like they're burning. Is that just the protectant of the metal getting burned off or should I look else where?
3.) The tiny vacuum hose that comes out of the plastic router looking thing in the back... Is there a real way to close that off or should I just put a screw in it like suggested in one write up?
4.) Where can I pick up gaskets for the AIR blockoff? One of my gaskets broke and now when the car starts up I can feel air escaping from that point. Would it benefit me to just remove that gasket and put some RVT sealant on the blockoff plate and let it set or track down said gasket and then replace it?
