soild motor mount pros/cons?
Old Mar 19, 2006 | 11:54 PM
phoenix's Avatar
Default soild motor mount pros/cons?
just wanted to know some of the pros and cons of a soild motor mount.
Old Mar 20, 2006 | 12:13 AM
The1N_only's Avatar
pros: the car will fell more solid
cons: you might feel a little more vibration... but that is subjective...
before you make the just to solid mount you should find a buddy that has them and ride in his car... but i dout you will notice too much differnce between solid mounts and poly ones
Old Mar 20, 2006 | 01:34 AM
SUX2BU's Avatar
Yeah and don't take advise from people who are gonna say anything bad about solid motor mounts unless they have driven a solid motor mount LS1. i have installed many solid motor mounts in LS1's and most of them couldn't tell a difference other than the car feeling ALOT more solid and responsive.
Old Mar 20, 2006 | 04:59 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
that is very true. I have one that has solid mounts and one that doesnt and there is a pretty big difference.
Old Mar 20, 2006 | 08:50 AM
Second_Infinity's Avatar
What about hitting large potholes... is cracking the aluminum block not an issue?
Old Mar 20, 2006 | 09:05 AM
TN94Z's Avatar
I have ridden in my buddy's car with solid mounts and there is a little different. The car definately feels more solid. As previoulsy stated though, I would try and ride in one before hand. That is the only real way for you to know if you will like them.
Old Mar 20, 2006 | 10:02 AM
Grimes's Avatar
why not compromise and get poly mounts?
Old Mar 20, 2006 | 10:21 AM
TN94Z's Avatar
That's a good idea
Old Mar 20, 2006 | 10:28 AM
phoenix's Avatar
well its not a daily driver, but i just wanted to see if it worth geting or not. i am trying to make this into a drag car more then a street car.
Old Mar 20, 2006 | 11:50 AM
The1N_only's Avatar
well if it is more of a "race car" then it shouldnt matter i'd go solid you'll like it
Old Mar 20, 2006 | 12:31 PM
phoenix's Avatar
what about this cracking the block?!?!
Old Mar 20, 2006 | 12:33 PM
The1N_only's Avatar
there is a lot of people that talk about it cracking a block but ive seen no proof... if your a worried about it run poly or a motor plate setup... but IMHO i'd run the solid mounts and not worry about it
Old Mar 20, 2006 | 01:17 PM
SUX2BU's Avatar
I daily drive my car wth solid motor mounts and i love it.
I think one guy a few years ago cracked hios block with solids but he was makin like 800-900 hp or something crazy lie that.
Old Mar 20, 2006 | 03:42 PM
TN94Z's Avatar
My buddy has had his solid mounts for as long as i can remember and has had no problems. He used to daily drive his all of the time. I also suggest getting them and not worrying about it if it is heading toward a track only car.
Old Mar 20, 2006 | 04:37 PM
HowellSoccer88's Avatar
I have the Spohn solid mounts and after I switched from stock I could tell a difference but only a good one...no excess vibrations or anything like that (about the same as stock).
Old Mar 20, 2006 | 05:03 PM
phoenix's Avatar
thats for the great info, i am going to go ahead and get the soild mounts
