REDLINE ON LS1?
Old Jul 18, 2002 | 02:19 PM
WS-6 BILL's Avatar
Default REDLINE ON LS1?
WHAT IS THE MAXIMUM RPM I CAN WIND OUT THE ENGINE IN EACH GEAR BEBORE DAMAGING THE ENGINE? IS IT 6,000 RPM? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 18, 2002 | 02:51 PM
RTCamaroSS's Avatar
Default Re: REDLINE ON LS1?
I changed my redline up to 6500 with the power programmer...
Old Jul 19, 2002 | 01:15 AM
TomQ's Avatar
i heard 6400 is safe for stock engine and thats what i have
Old Jul 19, 2002 | 01:17 AM
horist's Avatar
I revved to 6600 before I knew anything about our cars... and I got lucky no damage (that I know of... I really should do a leak down and compression test)
I'd be leary going over 6200 RPM.... the valve springs arent designed to go past that area and you may have valve float
Old Jul 19, 2002 | 09:35 AM
WILWAXU's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by horist:
<strong>I revved to 6600 before I knew anything about our cars... and I got lucky no damage (that I know of... I really should do a leak down and compression test)
I'd be leary going over 6200 RPM.... the valve springs arent designed to go past that area and you may have valve float</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Umm.. my car lives above 6200. It's been like that for over a year.... BTW: How did you go over 6200? tuning?
Old Jul 20, 2002 | 11:09 AM
Navy David SS's Avatar
For you that are raising your rev limiter above the stock 6150, you are asking for trouble - unless you have cam'd and headed your cars. I can show you some bent push rods (I mean like 'L' shaped ones) by hitting 6500 rpm's.
You will gain nothing or very little by going beyond the 6150 on a stock motor. Most of the power bands on our cars are in the 5700-5900 rpm range.
This is a different story if you have put in a cam or different heads. I have seen some crazy numbers than.
Good luck guys.
David
<small>[ July 20, 2002, 11:10 AM: Message edited by: Navy David SS ]</small>
Old Jul 21, 2002 | 08:01 PM
BlakeSS's Avatar
It is pointless to run a stock cammed LS1 above 6000 rpm.
These aren't 5.0 engines....
You are losing power in that range.
Blake
Old Jul 21, 2002 | 09:01 PM
Sears's Avatar
!Dial-up Director
With stock pushrods/valvesprings I would not recommend revving past 6200rpm
Justin
Old Jul 22, 2002 | 12:04 AM
NataSS Inc's Avatar
Be smart and safe. Dont run a stock motor past 6K
Old Jul 22, 2002 | 12:53 AM
MDL-01C5's Avatar
I pull to 7000RPM when racing--the stock bottom end is OK up to about there--though I wouldn't recommend staying there for any length of time...
(I have moly PRods, and 918's w/Titanium retainers, as well...with a 226/.591/112 cam and mildly ported heads...)
On a stock car, moving the rev-limiter up is a waste of time, and is inviting disaster. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jul 22, 2002 | 08:16 AM
TrentSS's Avatar
Blake hit the nail right on the head!! It's foolish to wind out a stock, non-cammed LS1 to 6,500 rpm's. Hell, our cars peak at 5,200 to 5,400 rpm's. There's absolutely no need in going that high with basically a stock set up.
Old Jul 22, 2002 | 05:45 PM
WILWAXU's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BlakeSS:
<strong>It is pointless to run a stock cammed LS1 above 6000 rpm.
Blake</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Really.. Hmm.. how fast is your car?
Have you put your car on a dyno? .. The only thing that keeps may car from pulling is the limiter, goes to about 314 rwhp at throttle tip in and stays solidly there till it hits the limiter (6600). If I wasn't afraid of the valvetrain I would turn it to 7000.
Old Jul 23, 2002 | 02:04 AM
BlakeSS's Avatar
[/QUOTE]Really.. Hmm.. how fast is your car?
Have you put your car on a dyno? .. The only thing that keeps may car from pulling is the limiter, goes to about 314 rwhp at throttle tip in and stays solidly there till it hits the limiter (6600). If I wasn't afraid of the valvetrain I would turn it to 7000.[/QB][/QUOTE]
John,
Many, many times on the dyno. If your car pulls to the limiter than its obviously your converter helping you out. My M6 peaks horsepower *right at* 5550 rpm. After that it starts dying.
A stock cammed/converted A4 F-body won't gain hp over 5800 rpm trust me <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Blake
Old Jul 25, 2002 | 03:24 PM
WILWAXU's Avatar
Umm.. I tend to trust my cars performance... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
