pacesetter install
Old Mar 26, 2006 | 07:39 PM
00transamnh's Avatar
Default pacesetter install
Hey,
Tried putting my drivers side header in today and i cant seem to work it in... has anyone had to do any fab work to get a set of pacesetters in? thanks
Old Mar 26, 2006 | 07:42 PM
HAWK915's Avatar
Mock-up your catted y before install. You will probably need to have the pipe ends expanded. It was need w/ my install and I have seen others post up w/ the same issue.
Old Mar 26, 2006 | 07:53 PM
daryl2cb@yahoo.com's Avatar
Jack the car up more, it will go.
Old Mar 26, 2006 | 08:16 PM
Toasty's Avatar
I used a lift, and it went in like butter, no problems whatsoever. You probably just need to jack the car higher.
If we got SLP longtubes to fit with a floor jack alone, Pacesetters should be easy.
Old Mar 26, 2006 | 08:32 PM
TUFAS4U's Avatar
check the little casting tab on the block. thats all that held me up, just ground it down a little bit and the header slipped right through.
Old Mar 26, 2006 | 09:55 PM
markp03's Avatar
they went in just fine for me. it helps to have an extra set of hands and a cooler full of beer too =)
Old Mar 26, 2006 | 10:39 PM
TheBlurLS1's Avatar
That's what she said...
Get the car high as hell. When i installed mine, i had the collector pointing straight at the ground when i installed mine. Had to do the same with a set of Kooks on a friends car.
You can also unbolt the tranny mount from the tranny crossmember and shove it over toward the passenger side of the car for a little more clearance. This defiantly takes 2 people to do.
Old Mar 26, 2006 | 11:17 PM
SSmokin 01's Avatar
Old Mar 27, 2006 | 12:17 AM
Ehatcher's Avatar
You may also want to take your steering joint off as well since it is on the drivers side . The ease of install was like night and day once it was off.
Old Mar 27, 2006 | 01:48 AM
lowchevy2go's Avatar
with your car on jackstands, get the jack and lay a block of wood on it longways and jack up on the oil pan or between the motor/trans. this will lift it enough on the sides to get the header in there. MAKE SURE WHEN YOU JACK IT UP.. DO NOT DO IT TO MUCH AND LIFT THE CAR OFF THE STANDS.. !!!
Old Mar 27, 2006 | 02:12 AM
Juiced2000SS's Avatar
Just get the car higher it will work. No extra modifications required.
Old Mar 27, 2006 | 10:03 AM
seth webster's Avatar
Get an extra set of hands to help. Get the car as high as possible (safely) we used an old set of wheels to get the back of the car of the ground and jackstands. We also had to take out 2-3 spark plugs and we thought we we're goning to have to grind that piece on the block but we didnt. It was tight but they went in pretty easily without those other 2 plugs in.
Old Mar 27, 2006 | 03:01 PM
john shea's Avatar
Like tufa says cut that nub off and be done with it.
Old Mar 27, 2006 | 05:14 PM
just so everyone knows... i just cut that casting block off and they slipped right in
thanks for the help
Old Mar 27, 2006 | 07:24 PM
Rescue Ranger's Avatar
thanks for the help
cool, thanks for the follow up. It seems its always either the block tab or the height of the car.
