how to seal exhaust?
Old Mar 27, 2006 | 09:20 AM
rgaynor85's Avatar
Default how to seal exhaust?
ok i have my PS LT's and ORY i have them slipped together and band clamped but the band clamps arent making a complete seal, wherethe 2 ends of the clamp meet there is still some leaking and u can hear it under the car especially on deceleration alot.
im wondering what i can use to seal it up, my only idea has been to use those muffler bandages they make and wrap the edge where the Y is slipped on the headers and then clamp over that and hope it doesn burn off real quick. anyone else got an ideal i dont wanna weld it becuase id like to be able to get it off and i do plan on gettin a new Y and catback in the future when funds are better lol
Old Mar 27, 2006 | 10:13 AM
navyblue2000's Avatar
spot weld? a stainless steel wider clamp (not a cheap 2 dollar clamp)? Other than that, bandages are pretty much it.
Old Mar 27, 2006 | 11:07 AM
rgaynor85's Avatar
yeah i have the walker stainless band clamps they are about 5-6 inches wide but they still arent sealing it completely.
Old Mar 27, 2006 | 11:09 AM
MeentSS02's Avatar
Kleeborp the Moderator™
You might try bubble gum
Band clamps kinda suck like that. Guess you could always have some flanges welded on.
Old Mar 27, 2006 | 11:25 AM
ShevrolayZ28's Avatar
I read that aluminum tape works well on exhaust joints. You can pick it up at Home Depot or Lowes etc.
Stainless Works suggests using high temp silicon to aid with sealing and allow for easy dismantling down the road.
Another way to get a better seal is to cut tree thin notches, ~0.5" in length, in each female pipe. This will allow for more flexibility in the female pipe, providing a better seal. (Also recommended by Stainlessworks.)
In each scenario, a band clamp is then used over the joint.
Old Mar 27, 2006 | 11:40 AM
ls1mongrel's Avatar
Tape that bitch, just use alot, I did mine and it makes a huge difference !
Old Mar 27, 2006 | 11:42 AM
Viper's Avatar
NAPA Torx clamps too, that's also what Stainless Works uses.
Old Mar 27, 2006 | 11:45 AM
Matt D's Avatar
Retired Street Racer
I tried high temp RTV gasket maker (the red stuff) and it did not work so great. My slip on collectors are leaking real bad. I am gonan try some of the aluminum tape.
Old Mar 27, 2006 | 12:43 PM
camaroextra's Avatar
if it cant be duct, its fuct
Old Mar 27, 2006 | 12:53 PM
daryl2cb@yahoo.com's Avatar
use an impact gun on them and snug them up, that will do it.
Old Mar 27, 2006 | 12:58 PM
TheBlurLS1's Avatar
That's what she said...
Go get some aluminum foil from the kitchen, fold it over a whole bunch of times with a whole bunch of layers. Take the clamp off and put the middle of the strip right on the end of the overlap of the pipes and wrap it around, put the band clamp on top of it, and use an impact to suck it down.
I tried a muffler patch on my driverside when i thought it was leaking, but it wasn't what was leaking. The patch turned rock solid and was a BITCH to get loose when i yanked my heads off to swap the lifters.
Old Mar 27, 2006 | 01:13 PM
rgaynor85's Avatar
im thinking of incorporating all your ideas, im think i may try putting some hig temp silicone on the endge of the overlap and then wrapping that with the aluminum tape or foil and then tightening the clamp down over that if that doesnt solve it i dont know what will
Old Mar 27, 2006 | 01:17 PM
T/AFOSTERWS6's Avatar
amen brother
Old Mar 27, 2006 | 01:58 PM
lgobraves's Avatar
I have them same problem. I have tried most of the things mentioned above and none of them worked. I'm just going to have flanges welded on. Hopefully that will be the end of the problem.
