please explain the coolant flow of the water pump to me
Thanks for any help.
I guess no one can confirm this?
Maybe ask some of the sponsers that build motor's. It would be interesting to know.
Air in the cooling system becomes problematic if it gets into the water passages surrounding the combustion chambers. This often causes localized boiling and that, in turn, allows hot spots to develop on chamber walls and they cause detonation. The problem with reverse flow is that with coolant flowing downward and air bubbles flowing upward; keeping air out of the Gen II cooling system was difficult.
Though the LS1 has a lower static compression ratio; its cylinder heads have improved combustion chamber design and intake ports that breathe better. Those features allow them to make more power. The clean-sheet-of-paper approach also allowed design of the cooling passages around the chambers to be more efficient such that the engine can put out more power than the Gen II but yet have coolant flow in the conventional direction to eliminate problems with aeration. With a better combustion chamber and water jacket design and improved antifriction technology in the block, pistons and rings; it made sense to go back to the normal-flow cooling system.
This may not answer the question, bit I definately didn't know it.
These quotes were taken from a link in JRP's FAQ
I should prob quote the actual article author, buuuuuuut im too drunk.
good night.
DJ
DJ
Coolant is drawn from the radiator outlet and into the water pump inlet by the water pump. Some coolant will then be pumped from the water pump, to the heater core, then back to the water pump. Coolant is also pumped through the water pump outlet and into the engine block. In the engine block, the coolant circulates through the water jackets surrounding the cylinders where it absorbs heat. The coolant is then forced through the cylinder head gasket openings and into the cylinder heads. In the cylinder heads, the coolant flows through the water jackets surrounding the combustion chambers and valve seats, where it absorbs additional heat. Coolant is also directed to the throttle body. There it circulates through passages in the casting. During initial start up, the coolant assists in warming the throttle body. During normal operating temperatures, the coolant assists in keeping the throttle body cool. From the cylinder heads, the coolant is then forced to the thermostat. The flow of coolant will either be stopped at the thermostat until the engine is warmed, or it will flow through the thermostat and into the radiator where it is cooled and the coolant cycle is completed.
im looking up the same thing now for a friend..
did you ever figure out what ones are what?
im thinking the round ones are the outlets, and the square ones are the coolant into the block, but im not positive at all..... id like a little confirmation.
the top pipe is the return.... so if water came out of the round ports, i guess that means that water leaves the block thru the round ones, and enters thru the square...
heh, good idea on that water thing.. i think i have a spare WP i can try that on.
on the LS1s stock cooling setup, the stock thermostat is on the intake of the waterpump....
directly behind the thermostat is a bypass that allows some of the heated coolant of the block to re-circulate... allowing the wax pill to heat up and the thermostat to operate.
on the aftermarket electric waterpump LS1 setup, the stock thermostat is gutted, leaving only the shell to use as a inlet. a SBC thermostat is placed on the exit of the waterpump/block.. just as in a normal SBC setup.
because the LS1s coolant exit is below the highest point of the engine, it has air bleeds at the top of the heads that constantly allow coolant flow to return directly to the radiator. any air bubbles present are removed thru this line, and are eventually "burped" from the system..
does that help answer your question?
