AIR & EGR removal
Old Jul 30, 2006 | 09:06 AM
TORCHD 02 TA's Avatar
Originally Posted by LuvMyZ
You want a qty of 2 so $18.
Thank you
Old Jul 30, 2006 | 10:14 AM
lgobraves's Avatar
I just took off the old stuff cut off the part that connects to the manifold and welded it closed. works great, cost nothing and looks real clean
Old Jul 30, 2006 | 11:01 AM
BobbyWS6's Avatar
Once I find somebody in my area that can delete that part of the program, I will be removing both systems. I am sick of hearing (my neigbors also) the popping coming from Air system check valves. Also, less junk to unhook during spark plug changes. Something my car is over due for!
Old Oct 23, 2006 | 10:05 PM
2_wacko's Avatar
I plan on doing this as soon as I get the block off plates and gaskets. What handheld tuner will delete the codes?
Old Oct 24, 2006 | 03:58 PM
KameleonTransAm's Avatar
Wait a sec...I'm confused. I thought 00-02 didn't have EGR?
Old Oct 24, 2006 | 03:59 PM
Tainted's Avatar
they dont but they still have AIR
Old Oct 24, 2006 | 04:14 PM
Tainted's Avatar
01-02 cars have the ls6 intake. the ls6 intake has no provisions for EGR.
Originally Posted by Juiced2000SS
Just did mine today. I got a check engine light for the egr almost right away but the car runs fine. I will tune it out in a couple weeks. Looks tons better without it. The put like 3 miles of rubber hose on these things for the a.i.r. system. What a waste.
^ He has a 2000 and said he just removed EGR
Originally Posted by TheBlurLS1
There is no EGR on an 02. EGR was from 98-00 f-bodies only
Originally Posted by TORCHD 02 TA
i see it on my buddies 00 TA right on the passanger head.
^ Two more accounts of 2000s having EGR one being from a moderator
Old Oct 24, 2006 | 04:20 PM
ZROCWS6's Avatar
01-02 do not have EGR. 2000 and lower DO.
Old Oct 30, 2006 | 07:30 PM
SOULPOWER's Avatar
does any of you guys have a pic of the air block of plates, and gaskets?
Old Nov 4, 2006 | 02:10 PM
kagato's Avatar
So what does AIR stand for and what does it technically do/purpose?
I am in the market for headers and I am concerned about passing emissions if I do no air egr headers
Old Nov 4, 2006 | 02:40 PM
  #32
2_wacko's Avatar
I believe the Air warms up the cats or something like that.
Old Nov 5, 2006 | 09:49 AM
  #33
marthastewart's Avatar
I dont see why you guys want to spend the money (as little as it may be) to delete these things that hurt your MPG, give you 0% hp gain, and increase the likely hood of failing your inspection.
The only purpose of doing this I have seen so far is to "clean up the motor". If one was making a show car with everything chrome I could understand, but for the daily drivers I dont see why.
Old Nov 5, 2006 | 10:00 AM
  #34
bjoneill98's Avatar
I'm in the market for headers too, and IMO, I think it would be a lot easier being able to just install race headers and delete the codes so you don't have to worry about block off plates and all of that other stuff. I think that's the biggest advantage.
Old Nov 5, 2006 | 11:13 AM
  #35
CAMAROZ28AQUINO's Avatar
mines a 98 and it doesnt have that ugly hose near the TB and my car is bone stock?
Old Nov 14, 2006 | 08:07 PM
  #36
ArrestMeRed99Z28's Avatar
if there is no place on top of your intake maifold near the throttle body with a 1 3/8 inch hole with a plug in it and two places for 10 mm bolts then you have an LS6 manifold, congradulations. No what you want to do is unbolt it and send it to me for free, I'll pay shipping
Old Dec 26, 2006 | 02:28 AM
  #37
99kamarokid's Avatar
the first pic in this thread, looks like a little motor..what do u do with those wires that are running to it???
Old Dec 26, 2006 | 05:19 PM
  #38
cabech984's Avatar
Im ordering Pacesetter LT's (race setup) and want to delete EGR & AIR. Is the only thing I need to do this, the block off plate/plug for the LS1 intake? Any help would be great!!
Old Dec 26, 2006 | 05:39 PM
  #39
kevins2000LS1's Avatar
GOOD question im going to do the same
Old Dec 26, 2006 | 11:22 PM
  #40
TheBlurLS1's Avatar
That's what she said...
Yes guys, all you need is a 1-3/8" adjustable freeze plug for the manifold if you get the "Race" headers.
