TB Bypass??
Old Apr 8, 2006 | 11:27 AM
bigchuck34's Avatar
Default TB Bypass??
I just did a TB bypass to my car. After I was done I was thinking...why can't I just get rid of the hoses all together? Can't I just cap off the nipples on the engine coolant line and the radiator to eliminate the hose all together? Has anyone ever done this or also thought about it? What do you guys think?
Old Apr 8, 2006 | 11:46 AM
98TADRIVER's Avatar
good question, but i think they leave em attached so it circulates maybe
Old Apr 8, 2006 | 03:16 PM
bigchuck34's Avatar
Anyone else with any suggestions?
Old Apr 8, 2006 | 05:33 PM
Venkman's Avatar
They're probably necessary. GM rarely overengineers anything it doesnt have to.
Old Apr 8, 2006 | 08:47 PM
LittleSlow1's Avatar
the stock TB coolant comes from the steam vent tube and then returns to the radiator. GM put thoses coolant steam vents on the engine for a reason i am sure. Capping off the nipples will not let the steam return to the radiator, and pretty much make that steam vent worthless. I just bypass the TB with a hose on mine car. If i were you i would do some reasearch on it before you cap them off.
Old Apr 8, 2006 | 10:58 PM
BackinBlack02SS's Avatar
https://ls1tech.com/forums/showthrea...ght=bleed+tube
Old Apr 9, 2006 | 11:51 PM
bigchuck34's Avatar
thanks for the link. I think I'll just bypass it and let it flow to be safe. sounds like everyone has their own thery on bypassing it or caping it off or leaving it alone.
Old Apr 10, 2006 | 12:05 AM
staringback05's Avatar
i did it to mine, and all i did was get a hose to run in between them runs fine, i never felt any kinda performance in it and i dont even think it did get any out of it, BUT it does make it easier to take the TB off and for me my car idles better when its hot out now...weird...
Old Apr 10, 2006 | 12:16 AM
00cls1camaross's Avatar
your not going to feel 1-2hp, but then again, i am going to do it because i want ever little drop of hp i can get
Old Apr 10, 2006 | 12:25 AM
TheBlurLS1's Avatar
That's what she said...
You will never get the damn air bubbles out of an LS1 car without that vent tube.
You CAN however, yank the old tubes out of the throttle body to clean it up a little bit. You just have to swist and pull like a son-of-a-bitch, but eventually they come out. I like to stick a screwdriver in them, get 'em moving around easily, then start to work them out.
I also just connected the vent tube on the motor to the radiator with one long piece of hose. I used a piece that would fit tight on the vent tube, and i just bored the inside out a little bit to fit on the radiator IIRC.
Old Apr 10, 2006 | 12:40 AM
Unhappy
ooo and the screw driver still took forever, thought id brake the damn hose in half...i dont like how low the hose sits next to the belt though
