Porting TB
Old Apr 10, 2006 | 01:18 AM
Shallow Bay's Avatar
Default Porting TB
I'm going to port and polish my throttle body with a Dremel and was wondering, what’s the best thing to use to cut, sand, and polish with? Also, approximately what RPM's should the above be preformed at? Any help is appreciated!
Old Apr 10, 2006 | 02:17 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
There are some great write-ups out there on how to do it. Search for TB Porting and see what you come up with.
Old Apr 10, 2006 | 01:44 PM
I didn’t ask HOW to do it but asked WHAT people were using. I agree there are some great write-ups out there but none of them really go into depth about what they used.
Old Apr 10, 2006 | 07:11 PM
GuitsBoy's Avatar
if youre using a dremel, get a high speed steel 1/4 cutter, cylinder shaped. hog out the material with that. Then get some 60 or 80 grit sanding drums, followed by 150 grit. Then polish using the scotchbrite pads. You can find all that stuff at your local home depot or lowes.
Old Apr 10, 2006 | 07:53 PM
Thanks man
Old Apr 10, 2006 | 09:25 PM
LS144's Avatar
I used a air compreser tool. You know the ones just like a dremel. And used a ball tip to port and grind down. and sand paper sand paper and more sand paper to smooth down the finish. I didnt notice a differenct at all but hell maybe the dyno would prove that wrong im not sure.
Old Apr 10, 2006 | 10:03 PM
camaroextra's Avatar
i hogged the **** out of mine, and i notices a nice difference
Old Apr 17, 2006 | 08:05 PM
SSmokin99's Avatar
Isn't there a sponsor who does it?
Old Apr 17, 2006 | 08:53 PM
WILWAXU's Avatar
https://ls1tech.com/forums/showthrea...2&page=2&pp=20
Old Apr 18, 2006 | 01:16 PM
MavrikTA's Avatar
Thank you!!! I have done this mod and all Ive ever had to do it with was a Dremil. None of the how-tos, cover what to use with a Dremil. Thanks. Maybe with the right bits it wont take 3hrs!
