getting dynatech's, which collector WON'T leak?
Old Sep 4, 2002 | 04:42 PM
highgmc's Avatar
Default getting dynatech's, which collector WON'T leak?
I am ordering dynatech's from jegs, I am getting the stepped version 1 3/4"- 1 7/8"
jegs sells collectors (but it doesn't look like they sell the merge version.
get the merge and have a leak? or do they all slip on and leak (looks like they all hook onto the 4 header tubes and can leak?)
jegs has a 3.5" standard slip on collector for $99
these are the 3.5" choices
primary size 1.75"
1.875"
2"
2.125"
which to get? or get the merge collector?
will one not leak?
I will be doig the flowmaster 6" mufflers, duals with turn downs just like george c.
help with the collector! what are you guys running for a collector? part#?
Old Sep 4, 2002 | 05:21 PM
XtraCajunSS's Avatar
Default Re: getting dynatech's, which collector WON'T leak?
I have the Dynatechs. Both of the collector types mount the same way. I have found no evidence of leaking on the collectors. Since the header tubes fit INTO the collector and are further upstream in the exhaust, they expand quickly and do not leak.
Shane
Old Sep 4, 2002 | 07:29 PM
Louis's Avatar
IF you get the coated headers, make sure that you silicone the collectors on using some hightep stuff like "ultra copper". If you can slide the collector on with out using a hammer, then they will have a greater chance of leaking. The car will stumble, run rich at idle, hesitate, and really annoy you.
Why do you want a 3.5 collector? a 3" with 1.875 primaries is what you need with the stepped version. IMO 3.5 is too large.
Louis
<small>[ September 04, 2002, 07:32 PM: Message edited by: G2 LS1 ]</small>
Old Sep 4, 2002 | 08:51 PM
GeorgeC's Avatar
If you're doing the exhaust similar to mine, you won't have any issues with the collectors leaking. Mine are just slightly "sooty" around the tubes going in to the collector, but it is a very small amount.
The merge collectors are quite a bit more expensive. I don't know that they would be worth the extra $$$. I have regular 3" collectors on my car, but may experiment with the stepped header/3.5" collector sometime in the future.
<small>[ September 04, 2002, 08:51 PM: Message edited by: GeorgeC ]</small>
Old Sep 4, 2002 | 10:46 PM
highgmc's Avatar
The car will stumble, run rich at idle, hesitate, and really annoy you.??????????????????????????????????????????
Old Sep 5, 2002 | 11:19 AM
Fireball's Avatar
if the collectors leak (like mine are right now) it will run rich as **** at idle <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
but being a smallish type leak...just put some copper RTV on the primaries and in the collector before assembling (I should've done this) I'll be doing this before too long <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Sep 5, 2002 | 03:51 PM
highgmc's Avatar
copper rtv fix this?
Old Sep 5, 2002 | 07:28 PM
Louis's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by terry99ta:
<strong>copper rtv fix this?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It doesnt take much. Down at the collector, you only see temps in the 5-600 range, maybe a little more, but the Ultra Copper will not deteriorate.
It doesnt take much to make the O2 sensor read lean. As soon as it reads lean, it adds fuel.....then it runs pig rich, and stumbles, hesitates, and it will really annoy you!! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
