Does anybody have an answer?
Old Sep 7, 2002 | 10:57 PM
OfficerZ28's Avatar
Default Does anybody have an answer?
I've posted this in the appearance section, braking section, but nobody seems to want to answer. So, i'll try it here...
I bought caliper spray paint..i just need to know how to take the calipers off...the guy at pepboys said theres two bolts holding them on...just take out the bolts, remove calipers, spray em, torque <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> em...Is it that easy?? Is it a must that i remove the brake line?
WHAT IS THE TORQUE FOR THE PINS HOLDING THE CALIPERS TOGETHER??
Old Sep 8, 2002 | 12:18 AM
J'sRamAir's Avatar
Default Re: Does anybody have an answer?
Here...read this: http://www.installuniversity.com/ins...er_rebuild.htm <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 8, 2002 | 07:59 AM
PontiacMan7901's Avatar
you don't need to remove the brake line...just more headaches for you. the paint you have is more than likely a very thick epoxy type paint and is brushed on...in this case you can leave the caliper connected and just paint it as it dangles...careful the paint is highly toxic, so just wear a respirator or a painters mask
Old Sep 8, 2002 | 08:17 AM
unit213's Avatar
Administrator
DON'T brush on paint. Use spray paint. There are only two bolts holding your calipers on. Yes, it's that easy. Painting your calipers are very easy and they look awesome. There are a few pics in my sig that may help.
Dan
Old Sep 8, 2002 | 08:20 AM
unit213's Avatar
Administrator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PontiacMan7901:
<strong>you don't need to remove the brake line...just more headaches for you. the paint you have is more than likely a very thick epoxy type paint and is brushed on...in this case you can leave the caliper connected and just paint it as it dangles...careful the paint is highly toxic, so just wear a respirator or a painters mask</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Don't use any of the infor above /\ other than the fact that you don't need to disconnect the brake line. Don't let your caliper "dangle" from the brake like either. Support it with something. A repirator/mask is completely unnecessary.
No flame intended to PontiacMan7901. Just simplifying things.
Old Sep 8, 2002 | 11:27 AM
Fulton 1's Avatar
If all you're doing is painting the calipers then you can do a perfectly adequate job without removing them at all. Take a look at the following link from jmX's website: http://ls1.fbody.com/install_paintcalipers.html
When I painted mine last year I put the car on jackstands in the front and removed the front wheels. I did one caliper at a time and turned the steering in the opposite direction of the side I was working on (this allows better access to the back side of the caliper). I then used some plastic grocery bags to cover the rotors. You can tuck these bags between the rotor surface and the pads. I then covered the inner and outer fenders with newspaper and masked off everything else I didn't want paint/overspray on. Rears work the same way, but no steering obviously.
EDIT: Oh yeah, I used a spray-on caliper paint good for 900+ degreesF from Dupli-Color followed by a hi-heat clear coat. I did four coats of the paint and two coats of the clear. Make sure you get those calipers nice and clean beforehand too. Eastwood makes a nice pre-cleaner for removing grease, oil, etc., prior to painting. I can email you a pic of mine if you're interested.
If you DO feel the need to remove the calipers here's a good install doc on that too: http://www.installuniversity.com/ins...ds_mwarren.htm
HTH
<small>[ September 08, 2002, 11:33 AM: Message edited by: Fulton 1 ]</small>
Old Sep 8, 2002 | 01:11 PM
J'sRamAir's Avatar
There was no need for me to remove mine when I painted mine. Pics in sig. <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
Old Sep 8, 2002 | 01:52 PM
OfficerZ28's Avatar
the paint is not sticking....whats going on here...well, its only the third coat, and im still doing the fronts....
Old Sep 9, 2002 | 12:33 AM
OfficerZ28's Avatar
Is the inside brake pad supposed to just fall out like it did?? or is it supposed to be hooked to something....this is my first time ever messing with disc brakes....thanks for being patient guys...heres one for you guys <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old Sep 9, 2002 | 08:06 AM
unit213's Avatar
Administrator
The paint isn't sticking? That's odd. You cleaned the calipers off well right? I used Simple Green and a scrub brush to start. Then I used a dremel followed by sandpaper. I put one coat of primer on then 3 coats of red paint. I finished them off with 2 coats of high temp clear.
