Professional Products Intake Manifold
Those of you who have them on order should be receiving them very soon.
With respect to a burst panel, a cast aluminum manifold will not explode as easily as the plastic ones. Our manifold does have a flat aluminum panel on the bottom of it that is 2.5mm (0.098") thick. In the case of a violent backfire it would probably pop without damage to the manifold. Normally cast aluminum manifolds do not have any type of pop-off valve or burst panel unless it is a blower manifold.
Here is my engine, can I get one of your LS1 versions with the 85mm inlet and fuel rails right now (and use my stock TB), or would I need to wait on your fuel rail regulator thingy?
Until our kit is ready for engines that do have a regulator as part of the fuel rail assembly (1997-'98), you can assemble all the necessary parts from current aftermarket suppliers. There is a diagram in our manifold instructions that should give you enough info to plumb up what is needed.
On our dyno tests we ran the stock t.b. and made over 500 hp with cam and heads and our manifold. Could we have made more with a bigger t.b.? Probably.
Like the stock 91mm t.b. our 96mm unit is designed with a spherical opening so that at part throttle you are seeing much less butterfly opening on the throttle body than you see with a straight bore t.b. This is so when you first start to open the throttle you don't let too much air in and cause a stumble.
That said, if you are running a relatively stock engine, I would certainly stick with the 85mm unit. As I said before, we squeezed over 500 hp out of one of these engines with a stock throttle body.
Thanks!
So is this manifold going to support boost? 15 PSI pushing against such a thin panel..... has any testing been done in this area?
