Professional Products Intake Manifold
Old Jun 22, 2006 | 10:57 PM
  #281
smok'nZ's Avatar
MASS seller approved
damm someone here in tulsa oklahoma already got one the other day ill be ordering mine when the 96mm comes out
Old Jun 23, 2006 | 12:15 PM
  #282
jimdavis@professional's Avatar
LS1TECH Sponsor
Originally Posted by a98ws6
It wont be stock but stock heads. Its going to be a forged 347, with a BIG cam and ALL the bolt ons. Set up for drag racing mostly. Also how much gain would one see if they went with a 85mm intake and stock TB over a 85mm with your 85mm TB?
Thanks!
Sorry, I really couldn't say but my guess would be that there would be enough difference to justify the 85mm t.b. Our 85mm t.b.'s will retail for well under $200.
We will not be offering a package with a manifold and throttle body but that seems like something that our retailers would be doing once the t.b.'s are available.
Old Jun 23, 2006 | 12:23 PM
  #283
LS1TECH Sponsor
To answer some questions that were raised earlier.
1. The NW90mm throttle body will bolt right up to our LS1 manifold with the 96mm inlet or our LS2 manifold with the 96mm inlet.
2. The manifolds are made in China by a factory that produces O.E. manifolds for several automobile and truck manufacturers. It is a state of the art facility. All of the design and testing is done here in the U.S. We are a U.S. company owned and staffed by U.S. citizens. Our company also produces parts in China for both GM and Ford.
Old Jun 23, 2006 | 12:28 PM
  #284
LS1TECH Sponsor
Originally Posted by Draco
So is this manifold going to support boost? 15 PSI pushing against such a thin panel..... has any testing been done in this area?
That panel will easily handle 15PSI of boost. Our bottom panel is thicker than the Weiand panel and I haven't heard of any problems on that setup with a blower. We have pressure tested ours to 25PSI with no problems. We didn't take it any higher than that.
Old Jun 23, 2006 | 12:57 PM
  #285
JasonWW's Avatar
Will the finish of the polished intakes be clearcoated or raw metal?
Old Jun 23, 2006 | 01:48 PM
  #286
tbick's Avatar
so some of the 85mm intakes are ready for sale, but when can one expect to be able to purchase the 85mm tb to go with it?
Old Jun 23, 2006 | 02:28 PM
  #287
Hennytime's Avatar
im still a tad concerned with the heat and intake temp issues that the weiland had. in testing how long did you run the car and what were the temps compared to stock...
Old Jun 23, 2006 | 04:43 PM
  #288
02SS:ZEUS's Avatar
Okay, I just ordered the polished 85mm from Byunspeed...great guys to work with by the way. The first opportunity I will have to put it in won't be until July 14. I will be swapping it out with my LS6 with no other changes. THERE WILL BE A DYNO RUN BEFORE AND AFTER THE INSTALL(same day to be as accurate as possible). I will post the numbers and probably a few pics on the 15th to see how much of an improvement it is over the LS6.
Old Jun 23, 2006 | 05:46 PM
  #289
Louie83's Avatar
You, sir, are my hero.
Old Jun 23, 2006 | 08:06 PM
  #290
duke of cruel's Avatar
Originally Posted by DuronClocker
Yeah, I'm going to stick with the LS6 manifold I bought a few weeks ago because this wasn't ready then when I ordered it I'm going to wait to see how the LS2 design for LS1 cars works out against a FAST. If this manifold is even within 5hp or so of a FAST on a stock setup, I'll be ordering this setup. If its better than a FAST, even better then
the ls2 manifold is the ls6 far superior, only problem is that the map sensor is located a nother place, but it flows a lot better.
DoC
Old Jun 23, 2006 | 08:10 PM
  #291
Is 96MM too big for stock cubed motors? Mines going to be a high reving drag car but dont want to go overboard with the intake? What would you guys recomend?
It is ok with a large tb on an injection system, because the air is not gonna drag the fuel in to the cylinder like a carb. i use 105mm on the 3,8l tt porsche´s i build on a aluminum inlet manifold.
DoC
Old Jun 23, 2006 | 10:02 PM
  #292
Jon B.'s Avatar
Holy crap, DoC, you are my new best friend. I LOOOVVVE 928's. I had an '85 up until not too long ago. From the looks of it you have a GTS, nice ride. My buddy has 2. Love those cars.
Jon
Old Jun 24, 2006 | 01:09 AM
  #293
Hennytime's Avatar
one question on the fuel rails, is there going to be a schrader valve for a wet nitrous kit or will a t fitting be used?
Old Jun 24, 2006 | 11:36 AM
  #294
who281's Avatar
i have a question if all i have right now is bolt-ons but i am soon getting a set of ls6 ported heads and a 228/228 cam from TSP would the 85mm manifold be good or the LS6 be better???
Old Jun 26, 2006 | 11:45 AM
  #295
LS1TECH Sponsor
Answers to several questions:
1. Clearcoat or raw metal? We have tried clearcoating manifolds in the past and unfortunately the stuff turns yellow and peels off over time. So we do not feel that is a viable option. We have been selling polished manifolds for nine years with great success. With just a minor amount of care you can keep them looking very good for a long time.
2. When will 85mm t.b. be available? Look back through previous responses. That question has been answered several times. Right now my best guess is about 90 days.
3. Temperatures during testing? All of our dyno tests were done on an engine dyno, not on a chassis dyno with the engine in a car. As far as engine operating temperatures, they were in the normal range.
4. Schrader Valve? The factory Schrader valve is brazed into the fuel rail and cannot be removed. We provide a 1/8-npt pipe thread in the end of one rail and provide a part number for a Schrader valve available at any Ford dealer that will screw into that tapped hole for those users who need this valve.
Old Jun 26, 2006 | 12:28 PM
  #296
1BAD02WS6's Avatar
i installed my intake yesterday on my 383 stroker. IT has a few flaws that need to be fixed but all around a good intake. it will be getting dynotuned tomorrow so will see what kind of power it makes with a larger cubed motor. its fed by stock maf and ported t.b
1. the npt fitting in rear for brake booster is covered by the oil pressure sending unit. cannot use it.
FIX used a 3/8 tee on other side to feed both vacuums
2. the way the map sensor is attached interferes with oil pressure sending unit. cannot plug both in
FIX I ran a bead of silicone around the map sensor and pointed the connector straight up.
3. the fitting for the stock fuel hose is a tad to long. wouldnt plug in.
FIX i trimmed aabout 1/16 off the end
4. the throttle/cruise cable braket interferes with the fuel rail
FIX i trimmed 1/3 inch off the side.
5. stock valley cover bolts are too tall not allowing the intake to seat up.
FIX went to autozone and bought shorter head bolts
6. you cannot use ls1 style coolant crossover tubes.
FIX bought ls6 style crossover tube.
All in all the intake is very nice. not alot of flshings. pretty smooth inside and out. I expected some flaws since it was so new. and the ones it has are easy fixes. Im happy and just hope it makes some power.
Old Jun 26, 2006 | 01:19 PM
  #297
LS1TECH Sponsor
Thanks for this input. We will get to work on making those fixes. I am surprised about the valley cover bolts being too tall. We didn't see that on the engines we have had the manifold on. Possibly GM has used some different style bolts on different model years.
Old Jun 26, 2006 | 10:05 PM
  #298
chrismcdaniel's Avatar
ls6 valley covers have shorter bolt heads than LS1 Valley covers.. i think... well, thats what a freind told me.. ok, im not sure... DANG!!
Old Jun 27, 2006 | 07:26 AM
  #299
98Z28CobraKiller's Avatar
Restricted User
FYI. Well, the FAST intake comes with replacement valley cover bolts that have rounded off allen heads for additional clearance.
Old Jun 27, 2006 | 06:08 PM
  #300
wilwhite2kss's Avatar
If the test are good maybe we could get a gp on it, and get it even cheaper. Seems like there are alot of people interested in it.
