Professional Products Intake Manifold
1. the npt fitting in rear for brake booster is covered by the oil pressure sending unit. cannot use it.
FIX used a 3/8 tee on other side to feed both vacuums
2. the way the map sensor is attached interferes with oil pressure sending unit. cannot plug both in
FIX I ran a bead of silicone around the map sensor and pointed the connector straight up.
3. the fitting for the stock fuel hose is a tad to long. wouldnt plug in.
FIX i trimmed aabout 1/16 off the end
4. the throttle/cruise cable braket interferes with the fuel rail
FIX i trimmed 1/3 inch off the side.
5. stock valley cover bolts are too tall not allowing the intake to seat up.
FIX went to autozone and bought shorter head bolts
6. you cannot use ls1 style coolant crossover tubes.
FIX bought ls6 style crossover tube.
All in all the intake is very nice. not alot of flshings. pretty smooth inside and out. I expected some flaws since it was so new. and the ones it has are easy fixes. Im happy and just hope it makes some power.
Any updates on this?????????
ALRIGHT !!!!!! It's about bloody damn time
