Steering column clearance with QTP longtubes
Old Apr 30, 2006 | 04:30 PM
Roarin_8's Avatar
Default Steering column clearance with QTP longtubes
Here's my clearance. Anyone else's looks like this or have better clearance than this with these headers?
Old Apr 30, 2006 | 04:52 PM
theinstag8r's Avatar
my fathers pacesetters had the same problem, he loosened both bolts on the steering shaft and slid it down, that changed the angle and gave him about 1/4-1/2 clearance from the header
Old Apr 30, 2006 | 04:56 PM
Roarin_8's Avatar
Ok thanks.
Old Apr 30, 2006 | 07:37 PM
NviouSS's Avatar
i never had that problem.
Old Apr 30, 2006 | 09:18 PM
Drew's TA's Avatar
When I installed my headers, the headers were bumping the steering column. My motor mounts had some play in them so we unbolted the motor mount and just moved it a little and rebolted it, no problems since.
Old Apr 30, 2006 | 10:05 PM
Roarin_8's Avatar
I'll see what the guys can do when I go back for the tune on Tuesday.
Old Apr 30, 2006 | 10:51 PM
01 Red WS6's Avatar
I have more room than that with mine
Old Apr 30, 2006 | 11:11 PM
Zymosis's Avatar
I wonder if they have slightly changed their design...I see this thread with no clearance by the steering column...and another thread where a guy had to grind some of his frame for clearance....
My QTP's slid right in, and I would guess I have around an inch of clearance there.
Old Apr 30, 2006 | 11:26 PM
Roarin_8's Avatar
damnit
Old Apr 30, 2006 | 11:57 PM
TheBlurLS1's Avatar
That's what she said...
Ewwww. Has it messed up the header or is that a reflection?
Every car is different, those headers might slide in purty on someone elses car. That one set of headers might also be a little tweaked, which happens in manufacturing all the time.
BTW - when you unbolt that section of the steering shaft, make sure you put a little blue loctite on the set screws, they come with thread locker from the factory and I'd hate to see one fly off.
Old May 1, 2006 | 05:15 AM
tder1's Avatar
Do you know if your Rack may have been changed at one time? Some Aftermarkets change the angle of the Shaft and make Header install a nightmare. There's a big difference. I've been through it. Only thing you can do is Loosen the Shaft, slide it down and play wth it. Make sure your comfortable with the length of engagement of the top sleeve of the shaft. As long as you can feel play when you grab and shake your steering shaft, it's not touching and should be OK.
Old May 1, 2006 | 07:06 AM
peterock98's Avatar
Loosen all the header bolts and push up the collector from the bottom.You need 2 people.I also ripped off the QTP logo when I did this it gave me clearance clarence.If that don't work take the header back off header heat it up with a torch. Heat up that spot until it's red hot and ding it.
Old May 1, 2006 | 08:14 AM
Roarin_8's Avatar
I'll see what can be done. Yea the damn shaft rubbed on the header so now it has that little rub mark. Maybe it will come off, but who knows.
Old May 1, 2006 | 08:20 AM
peterock98's Avatar
Are you back in the Bronx or are you in Fla still?Make sure you do something about it.The Steering linkage won't brake but you might damage the header .
Old May 1, 2006 | 08:41 AM
Roarin_8's Avatar
I'm in the Bx. I have to take it back to TTP to finish the tune and I'll make them aware of the clearance issue with the header. I knew that my steering felt strange for some reason and that's when I noticed the clearance problem. The car sounds badass Pete, you gotta hear it one day.
Old May 1, 2006 | 09:25 AM
TTPMatt's Avatar
Now I'm aware of the issue... When you bring it back in we will see what we can do with those QTP's.
- Matt
Old May 1, 2006 | 10:01 AM
Roarin_8's Avatar
I was just about to pm you the pics. Ok no problem, I'll be there a little before 10 tomorrow. See you guys then.
Old May 1, 2006 | 10:39 AM
slow trap's Avatar
i'm a machinist so i done what a machinist/fabricator would do=i took it off,scribed a straight line down the side of it,cut out a 3" long section and welded a smaller diameter piece in.mine was rubbing so bad the steering wheel was hard to turn but now no problems,of course having metal and a mig welder at my disposal makes it much easier.maybe ttp can adjust your headers some.
Old May 1, 2006 | 11:08 AM
TTPMatt's Avatar
I am sure we can work with this. If it's a slight fitment issue there's reasons why I spent $110 on a prybar 57" long
Just kidding Gabriel, we'll see you around 10 tomorrow to wrap it up.
Old May 1, 2006 | 11:33 AM
Roarin_8's Avatar
Ohh noooo a pry bar!!! no prob, see you tomorrow.
