More BGRA questions
As far as your questions go, I don't have the slightest clue.
00'WS6Rocket: Yes, I am definately interested in some pics if you could post them, did you use the existing pieces that they still sell?
I'd like to know this also......pics would be great!
OK this pic is just the gaskit bolted bolted on to my car// all I used was air tools to drill out the baffles then i drilled holes on to the gaskits where they would line up with the holes on the hood.. the silver tape in the middle on the top and bottom will be explained below..
this pic is the rain blocker that I drilled 2 holes bottom and top to line up with the 2 middle holes on the hood ( silver tape with holes ) the reason I put the tape is cause I used wing nuts so the rain blocker is easy on and off and the gaskit was too thick to use the wing nuts..
this is the pic with the rain blocker on my car.. I put the rain blocker in the ram air hole and make the bolts come out toward the engine bay and put the wing nuts on the top and bottom to secure it..
got any more questions just ask
id be willing to sell mine since im going with a procharger setup soon... but only for the right price seeing that you cant get this anymore. you will need new gasket since my nitrous lines cut them a lil bit, but you can still buy those. as seen in the picture i also have the end pieces to complete the look
There are no holes on the gaskit other then the ones that you drill out thoose spots that you see that look like holes are actually holes that run through the gaskit part but not through the back( the back is a hard plastic that the gaskit is glued on to ).... the top two fit in the holes in the gaskit part ( still have to drill through the back) the rest i had to drill into the gaskit and out through the back. it took prolly 2 hours to totally remove my baffles and do all the drilling in to the gaskit and the rain gaurd and put it together. of course i had air tools it might take longer for a battery/electric drill.
The arrows are where the screws are that scrw into the hood and the circle's are where the holes are where the rain gaurd fits in to
Ithink i bought the gaskit and the rain gaurd for about 50bones.
