Installing headers today
Old May 12, 2006 | 06:13 PM
musclebird69's Avatar
Default Installing headers today
Installing my headers today, and i can't get the damn cat bolts off! Im pretty frustrated. Any tricks guys? I've managed to take one off, it broke off.
Old May 12, 2006 | 06:31 PM
2K2WS6TA's Avatar
Just break them off, you're replacing all the stock stuff anyway
Big breaker bar and some muscle and SNAP problem gone
If you want to try and save them, try soaking them with PB Blaster and wait an hour or so
Old May 12, 2006 | 07:07 PM
Order 66's Avatar
Use some wd40 on the bolts and just let it sit for a while. The spray it again. Get a socket on it and breaker bar and give it a good turn. You might need a little heat to break em loose.
Old May 12, 2006 | 07:43 PM
Ws6Extreme's Avatar
I used WD40, and a 1/2 drive wrench. Then apply A LOT of force (recommend you wear gloves otherwise you WILL bust a knuckle) and watch it either come lose or break.
Old May 12, 2006 | 07:46 PM
conan's Avatar
The ones I could get the air gun on SNAP = done.
Old May 12, 2006 | 08:26 PM
Order 66's Avatar
Gloves! Great recomendation. I dont know how many times when the nut finally breaks free and the my knuckes get a nice shaving.
Old May 12, 2006 | 08:28 PM
mrhzk35404's Avatar
I ran all of mine off with an air gun and none of them broke.
Old May 13, 2006 | 12:45 AM
TheBlurLS1's Avatar
That's what she said...
You should quit your job and start buying lotto tickets.
Old May 13, 2006 | 12:48 AM
Justin00SS's Avatar
I am installing mine tommorow and I can't find that damn "How to".
Old May 13, 2006 | 01:18 AM
TheBlurLS1's Avatar
https://ls1tech.com/forums/showpost....64&postcount=2
Old May 13, 2006 | 04:27 PM
Raise's Avatar
go eat a steak and find your nuts
Old May 13, 2006 | 07:21 PM
erikthegoalie's Avatar
i didnt bother.....i left cats on and removed the whole manifold/cat assembly....just tweak it it came out failrly easily!
Good luck...
Old May 13, 2006 | 11:26 PM
mrhzk35404's Avatar
Sounds like a great idea. But I haven't had luck with the lotto yet.
Old May 14, 2006 | 02:55 AM
Shallow Bay's Avatar
Same here
Old May 14, 2006 | 05:39 AM
DaddySS's Avatar
Soak them good with wd-40 or some other "rust buster", rap them good with a hammer (use an old extension if you have one with the socket on it, place it on the nut and the rap it with a hammer or use an impact gun set on low) the viration helps the wd-40 to penetrate. Do that a few time before trying to take them off, a good overnight soak is best. Then use an impactwrench if you have one, set on low so the impact starts to break the rust. Take your time and in most cases you can get them off. Of course if you have a torch, heating them up really good before you try to take them off is even better.
