LS1 to LS6 Intake Swap
Old May 25, 2006 | 07:31 PM
Brett H's Avatar
Default LS1 to LS6 Intake Swap
Can someone give me a rundown on exactly what is needed to do an LS1 to LS6 intake swap please. What I need to know is will I need to change or modify my valley cover and what about the coolant lines? I know its been posted before but I did a search and came up empty and I don't have a lot of time as the intake I want will likely be sold soon.
Also is an LS6 intake's part number 12573572?
Thanks,
Brett
Old May 25, 2006 | 07:44 PM
white_camaro's Avatar
all youll need
http://texas-speed.com/shop/category...MID=1&catid=12
Old May 25, 2006 | 10:32 PM
Y2K Pewter SS's Avatar
http://ls1howto.com/index.php?article=5
Should give you everything you need/want to know, good luck with it.
Old May 26, 2006 | 08:18 AM
allngn_c5's Avatar
Why don't you just upgrade to the FAST? Just curious.
Old May 26, 2006 | 08:34 AM
taintedmeat's Avatar
The extra $500
Old May 26, 2006 | 09:04 AM
C.J.'s Avatar
Originally Posted by taintedmeat
The extra $500
haha no kidding
Old May 26, 2006 | 11:12 AM
Justin00SS's Avatar
Old May 26, 2006 | 12:32 PM
allngn_c5's Avatar
Extra $500 ?? I only paid $500 for my FAST in the first place. Maybe you guys are getting ripped off. I had the option for 78mm LS6 for $459 or 78mm FAST $500
I chose the FAST Enough said.
Old May 26, 2006 | 01:01 PM
Asmodeus's Avatar
there's a difference between the LS6 and the 78mm fast?
Old May 26, 2006 | 01:05 PM
allngn_c5's Avatar
I was told that I would make more power by taking advantage of my VaraRam ram air setup using the FAST vs the LS6. Please explain if I was misinformed.
Old May 26, 2006 | 01:26 PM
TheBlurLS1's Avatar
That's what she said...
You were misinformed. It's only a good upgrade if you can get the LSx 78 for the same price as an LS6. The gains are very small and you could spend the money in better places.
The FAST 78 is a good setup if you want to do a nice direct port system due to the designated spots for it, but if you can afford a direct port system, you should have enough cheese for the FAST 90.
Old May 26, 2006 | 01:53 PM
2000silvergtp's Avatar
Very informative link.
