How much lower down coating REALLY lower header temps?
Old Feb 11, 2003 | 08:58 PM
Damian's Avatar
LSX Mechanic
Default How much lower down coating REALLY lower header temps?
I am trying to decide wether or not I should blow another 125+ bucks on coating my Grotts. I am not worried about longevity, so don't throw that one out there. Some high temp engine enamel can take care of that...
Any hard core evidence that coating reduces temps enough to warrant paying the extra $?
I ran uncoated Macs for over 2 yrs without a single problem...
Old Feb 11, 2003 | 09:45 PM
LS69TA's Avatar
Default Re: How much lower down coating REALLY lower header temps?
Coatings will make it a few degrees cooler, but header wrap will make a HUGE difference in underhood temp. It'll feel just like it does outside the car under the hood. just dont get any fluids on it-trans. fluid, oil,etc. because it WILL DEFFINATELY catch on fire!!!!
<small>[ February 11, 2003, 09:46 PM: Message edited by: C-Note ]</small>
Old Feb 11, 2003 | 10:02 PM
promod1955's Avatar
They claim 200 degrees. It is worth it. between the rust prevention and lower temps i wouldnt hesitate to spend that.
Old Feb 11, 2003 | 10:10 PM
5LiterBeater's Avatar
Hey promod I am in Norfolk, VA. Are you part of the T/A club here?? And also I didn't think that the ceramic coating lowered temps that much. 200 seems to be a bit high.
Old Feb 12, 2003 | 12:09 AM
68LSS1's Avatar
I think there could also be a performance/hp issue here also. As the exhaust gasses cool down they slow down. With a wrapped/coated exhaust the velocity should stay higher meaning better scavenging.
Old Feb 12, 2003 | 09:56 AM
Biochem's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by C-Note:
<strong> Coatings will make it a few degrees cooler, but header wrap will make a HUGE difference in underhood temp. It'll feel just like it does outside the car under the hood. just dont get any fluids on it-trans. fluid, oil,etc. because it WILL DEFFINATELY catch on fire!!!! </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So you're telling me that if I spring a small oil leak or accidently spill some misc. engine fluid on my header wraps, that they may/will burst into flames? Bummer! Aren't they supposed to be made of non-flamible materials?
Old Feb 12, 2003 | 10:00 AM
m1key99WS6's Avatar
It won't catch on fire. I had a 66 GMC truck with long tubes and header wrap with leaky as all hell chrome valve covers and it just smoked and smoked and smoked, it never cought on fire. I drove it for a year like that, it just plain stinks and smokes. I'm sure if you spill gas on it or something it would, but hell, spill gas on any hot header and see what happens. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 12, 2003 | 11:05 AM
98sspullin'em's Avatar
im in the same boat as you coated or non coated headers, or just wrap the non coated one's? is it really worth it?
Old Feb 12, 2003 | 02:35 PM
LS69TA's Avatar
My 70 Chevy stepside DID catch of fire everytime the headers got hot. I had a tranny cooler line come loose one time and the bottom half of the header got soaked. It would smoke for a while, then it would start flaming up badly. So, yes, it will burn. But in our new cars, all you really have to do is be careful when changing oil or pulling valve covers.. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Feb 12, 2003 | 02:39 PM
LS69TA's Avatar
I took the wraps off and used the header jackets, which is what i'm going to use on my Camaro when I get my headers. Those seemed to work pretty well for me before, and are easier to put on and remove if needed. They allow some heat to escape but it's not too much. Gave my little 4cyl Ranger a little more get-up-n-go <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 12, 2003 | 03:34 PM
Fly By's Avatar
Header wrap will make the tubes brittle, and crack with time. I wouldnt use it. If you dont care about looks, just keep em like that. Temp is virtually unaffected, cept for some minor reduction.
Old Feb 12, 2003 | 04:23 PM
Fenris Ulf's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Damian:
<strong> I am trying to decide wether or not I should blow another 125+ bucks on coating my Grotts. I am not worried about longevity, so don't throw that one out there. Some high temp engine enamel can take care of that...
I ran uncoated Macs for over 2 yrs without a single problem... </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">For the price coating is definately worth it unless you have T304 or 321 stainless steel which has roughly a 1/3 of the heat conductivity of mild steel. Grots are mild steel I believe.
Old Feb 12, 2003 | 05:09 PM
BurnOut's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fly By:
<strong> Header wrap will make the tubes brittle, and crack with time. I wouldnt use it. If you dont care about looks, just keep em like that. Temp is virtually unaffected, cept for some minor reduction. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Exactly. Header wrap works TOO well; it holds in too much heat for the steel of the header to deal with. The result after a year or two is a thin, brittle header that leaks like a sieve and is damn difficult to repair. I'd stay the hell away from header wrap unless you like buying/installing new headers every couple of years. As for the high temp enamel, I haven't found one yet that will stay on a set of headers.
Old Feb 12, 2003 | 05:14 PM
gillbot's Avatar
Wha about POR15, they claim it will.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BurnOut:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fly By:
<strong> Header wrap will make the tubes brittle, and crack with time. I wouldnt use it. If you dont care about looks, just keep em like that. Temp is virtually unaffected, cept for some minor reduction. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Exactly. Header wrap works TOO well; it holds in too much heat for the steel of the header to deal with. The result after a year or two is a thin, brittle header that leaks like a sieve and is damn difficult to repair. I'd stay the hell away from header wrap unless you like buying/installing new headers every couple of years. As for the high temp enamel, I haven't found one yet that will stay on a set of headers. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old Feb 12, 2003 | 06:08 PM
Biochem's Avatar
<strong> [QUOTE]Originally posted by Fly By:
[qb] Header wrap will make the tubes brittle, and crack with time. I wouldnt use it.... I'd stay the hell away from header wrap unless you like buying/installing new headers every couple of years. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What about stock manifolds?
Old Feb 12, 2003 | 10:35 PM
promod1955's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 5LiterBeater:
<strong> Hey promod I am in Norfolk, VA. Are you part of the T/A club here?? And also I didn't think that the ceramic coating lowered temps that much. 200 seems to be a bit high. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey 5literbeater, im from Chesapeake. if you look on the inside cover of either the ihra or nhra rule book they show a thing that it was a 200 degree difference.....dont always believe everything you see in the rulebook though.... jest:
Old Feb 12, 2003 | 11:17 PM
If you look into the QTP headers (same design as Grots) they are now stainless steel. A much better quality than the older ones and don't need to be coated, nor do they rust. Just my two cents on that one. Give Barry a call and talk to him about it. He is always more than happy to.
Old Feb 13, 2003 | 01:39 AM
66ImpalaLT1's Avatar
Whether or not coating works with the engine running is debatable, but 10 minutes after shutting off the engine the difference is night and day.
Coating is worth not having burnt hands every time I need to check/change plugs on a hot engine.
Eric
Old Feb 13, 2003 | 11:38 AM
BurnOut's Avatar
Gillbot- I have never heard of POR15, so I can not say whether it will stick or not. I may have to revise my position ("paint won't stick to a header") soon... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Biochem- Wrapping stock manifolds will of course help reduce underhood temps, but IMO it is only a matter of time before you end up with a metal that has consistently exceeded its designed maximum temperature and becomes brittle as a result.
Don't get me wrong, I'm not saying that header wrap is useless, only that I think that it is a bad idea on a daily driver. Just my $.02...
Old Feb 13, 2003 | 03:46 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
I would think the wrap in our crowded engine bays COULD be a good thing, as far as wiring, etc getting overheated. As far as problems with metal fatigue occurring w/headers, IMO that would not be a problem w/SS (radiates quickly), and with mild steel I would think the wrap, if anything, would allow a longer cool down time, thus would make it less of a problem due to less rapid cycling of temp. I'm no expert on metal properties, although I do have some experience making alloys.
How the coatings work, I have no clue.
