Help Me Install My Catch Can Please!!!!
Old Jun 8, 2006 | 05:06 PM
Cooper01Z28's Avatar
Default Help Me Install My Catch Can Please!!!!
ok i orderd this catch can --- http://cgi.ebay.com/ebaymotors/ws/eB...MEWN%3AIT&rd=1
and i have NO idea how to install it...it came with no instructions, i looked on this site, but no one gives a good tutorial on how to install these...if you look at the picture on ebay, it shows everything it comes with, idk what that little filter thing is that has the hose with a nipple on each end of it....please help me out guys! pictures with a tut. would help out alot!
Old Jun 8, 2006 | 05:39 PM
monkey11's Avatar
sure it should have one IN and one OUT i dont think it matters which one. remove the PCV valve next to the TB, and replace it with the catch can, just look at the line and mount this unit somewhere close and run the lines should take a few min... you be happy with it, good luck man!!
Old Jun 8, 2006 | 05:43 PM
which hose tho? there are alot of hoses down there, i just dont know which hose to replace, and what is that filter thing for that came with the can? im soo confused..someone please post pictures!
Old Jun 8, 2006 | 06:01 PM
^^^what is that, that is right above the catch can? it came with it but what is it used for? THANKS FOR YOUR HELP EVERYONE!!!!
Old Jun 8, 2006 | 06:03 PM
does it get connected to the hose that is in the first picture posted? how should i put it inline with that hose? should i disconnect it hook it up to one end of the can, and use the hose given to me to connect to the other nipple on the can and to the niplle that original hose was on? IM SOO CONFUSED! AHHHHH
Old Jun 8, 2006 | 08:58 PM
FireSilverLullaby's Avatar
This should help!
https://ls1tech.com/forums/showthrea...ight=oil+catch
Old Jun 8, 2006 | 10:20 PM
yea, i saw that earlier, it helps a little bit, im still not sure what i do with that filter type thing that came with my set up
Old Jun 8, 2006 | 10:34 PM
do i need to remove the hose that goes to the back of the intake manifold? or can i just tap into it where tha big black thing is on the hose....?
Old Jun 8, 2006 | 11:22 PM
TheBlurLS1's Avatar
That's what she said...
Inside the "black thing" in the first picture of post #4 is the PCV valve (which you need to keep). I would not worry about putting the "filter thing" in at all. Does your camera have macro mode so you could get some better pictures of it? It almost looks to be just a male/male connector for extending a hose.
You need to unplug the "black thing" from the manifold and run it into one side of the catch can, then run the other side of the catchcan back to the manifold.
The way you run the hoses, and where you put the can, is up to you as long as they are connected in this order. You could get fancy and mount the catchcan over by the fuse boxes l like I did, or you can keep it over by the silver a/c canister.
You will find that the stock PCV system is put together with hard plastic lines slipped inside of rubber lines. You will also find that 3/8" rubber fuel line will slip right over the hard plastic lines and fit tightly without even using a hose clamp. I would be willing to bet that if you pulled that "black thing" off of the manifold, you would be able to pull the end of it off of the PCV valve, which should be a male fitting, and stick it inside the 3/8" hose.
I tell you what, I'll draft something on AutoCAD tomorrow at work so you can look at it.
Old Jun 8, 2006 | 11:25 PM
TheBlurLS1's Avatar
This is a good pic.
Originally Posted by Second_Infinity
Old Jun 9, 2006 | 10:45 AM
thanks alot blur!!! im going to try to get this done this morning! please try and ge that picture, if you have time...
Old Jun 9, 2006 | 01:13 PM
ok ill get some pics up in a bit of how i did it! tell me what you think
Old Jun 9, 2006 | 01:47 PM
CLICK ON THEM TO ENLARGE!!!!!!!!!!!
Old Jun 9, 2006 | 01:48 PM
tell me what you think of the set up?
Old Jun 9, 2006 | 02:10 PM
TheBlurLS1's Avatar
Looks pretty sweet! No need for CAD now!
I thought about mounting mine right there, but I was going to run the hoses between the battery and radiator somehow.
Old Jun 9, 2006 | 02:20 PM
cool thanks! so it doesnt matter which nipple i wput which hose on? ill end up runnin the hoses a dif. way i think i wanna get the braided ones
Old Jun 9, 2006 | 02:44 PM
TheBlurLS1's Avatar
It probably does not matter. Is there anything on the inside or is it just a cavity?
Old Jun 9, 2006 | 02:59 PM
i think its just a cavaty...im sure if it made a difference, there would be somethin on the can saying input and output or somethin...here is a picture that was on the side of the box that it came in...
Old Jun 9, 2006 | 03:12 PM
JD17825's Avatar
I have that same can why is there still a need to use the pcv valve ?
Old Jun 9, 2006 | 03:32 PM
im not sure, i just left it on there because i saw others did...
