TSP duals
Old Jun 9, 2006 | 04:59 PM
barracuda_440's Avatar
Default TSP duals
HEy guys, i was wondering if all of the TSP duals hang this low, lemme know.
Attached Thumbnails TSP duals-zoo-duals-036.jpg   TSP duals-zoo-duals-040.jpg   TSP duals-zoo-duals-033.jpg   TSP duals-zoo-duals-041.jpg
Old Jun 9, 2006 | 06:28 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Mine did before I flipped the fuel line
Old Jun 9, 2006 | 07:08 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Labatt Blue....
Old Jun 9, 2006 | 07:35 PM
BuBbABFP's Avatar
mine did, till i got them touched up by a muffler shop. mine where worse it was about half inch from the ground, but i have a PRO-KIT.
Old Jun 9, 2006 | 09:59 PM
mcflyz28's Avatar
Looks real familiar, gonna have to get mine to an exhaust shop for a tuck job
Old Jun 9, 2006 | 10:00 PM
well that clamp seems to be the lowest point so maybe i wll ahve it welded....i wish there was somthing else i could do.....
Old Jun 9, 2006 | 10:12 PM
white_camaro's Avatar
looks to me as if your x-pipe is on upside down. from the side the x-pipes should look as if they're going up to the mufflers, yours look like theyre going down.
i did the same thing when i first put mine on, got an extra 2 inches of clearance by flipping the x. try to turn the mufflers at a 45 degree angle too, unless you like interior rattles.
Old Jun 9, 2006 | 10:15 PM
i went from less than 3inches of clearance to at around 5 inches by flipping the x and messing with the pipes. try putting a jack or something underneath the mufflers and raise them up as high as you can without touching the body, then tighten down your clamps and hangers. I know you can get a lot more clearance than you have, just have to play around with the setup a little.
Old Jun 9, 2006 | 10:25 PM
ls1muscle's Avatar
Get rid of the clamps, have them welded. They need to be pushed up alot, like everyone has said, play around with the pipes and flip your fuel lines out of the way also.
Old Jun 9, 2006 | 11:47 PM
DirtyJohn's Avatar
I'ma go with X upside down, even with fuel lines flipped, you shuld not be at half a popcan.
I can't really see on the one pic with the X but thats what id check first.
Second flipe the fuel line and tuck it up with a jack and a 2x4".
You may have to drill again but that seems too low for that kit.
DJ
Old Jun 10, 2006 | 02:10 AM
Shallow Bay's Avatar
Also make sure the rear axle isn't hanging and it's supported by some ramps or concrete blocks.
Old Jun 10, 2006 | 09:24 AM
get rid of those u-clamps and get yourself some quality bandclamps!!if you ordered from tsp recently they should have sent you the band clamps not the u-clamps.
Old Jun 10, 2006 | 11:12 AM
I got them used from a guy in cali, im gonna have it welded soon, im gonna go throw it on the lift flip the X pipe i think. Can somone provide pics of their TSP duals? I am not lowerd and all stock suspension.
Old Jun 10, 2006 | 01:17 PM
DirtyJohn's Avatar
Check the link in my sig yo, if you need more help after that, PM me and I'll try and help if I can.
Old Jun 10, 2006 | 01:35 PM
TheBlurLS1's Avatar
That's what she said...
I also think the x is on upside down, but I'm not sure. I have pics of mine in my sig of the way it was before it ran out the back. You will need to flip the fuel lines and bash a few things in to get it riding as high as mine though.
