Intake swap on an A4
Old Jun 12, 2006 | 04:08 PM
Joel_SS's Avatar
Default Intake swap on an A4
Can you swap the intake maniflod on an Auto with the tranny dipstick tube in place? Just from looking at it I am not sure it would clear and that dipstik tube bolt is a PITA to get to!!
Old Jun 12, 2006 | 04:09 PM
BADFNZ's Avatar
The dipstick isn't in the way at all. The intake comes foward before it comes up. Just remember to raise it about an inch up before coming forward to clear the oil pressure sending unit.
Old Jun 12, 2006 | 04:16 PM
TheBlurLS1's Avatar
That's what she said...
You can give the dipstick tube a slight shove to move it the hell out of the way too.
Old Jun 12, 2006 | 04:25 PM
Xsta Z 28's Avatar
Yep. Little tighter quarters but it can be done.
Joel_SS's Avatar
cool thanks!
Old Jun 12, 2006 | 04:36 PM
s346k's Avatar
+1
so far this car's dipstick tube has been raped a couple times. header install and intake swap both...it helps moving it out of the way for either account.
a friend of mine has a th350 in his 99 z, the dipstick tube is in the cabin, right next to the shifter yeah..it looks kind of goofy. also the floormat poses as a shift boot/hole cover where the console once resided.
but i guess you gotta do what ya gotta do, eh?
Old Jun 12, 2006 | 05:14 PM
ilirw325's Avatar
the tranny dipstick has a 15mm bolt thats it attached to the back of the passenger head. once u undo that it moves VERY easy out of the way because it rocks in the little rubber grommet in the tranny. If you just shove it somethin on the dipstick will bend.
Old Jun 13, 2006 | 12:33 AM
SSilverSSurfer's Avatar
werd on that
Old Jun 13, 2006 | 10:24 AM
Joel_SS's Avatar
Crap!! I broke an intake bolt. Since I did not have an inch pounds I used my torque wrench and set it to 10ft lbs and it snapped a bolt off in the head! Anyone got a part number for a new set of intake bolts?
Old Jun 13, 2006 | 10:27 AM
ChocoTaco369's Avatar
Tech Resident
http://www.thunderracing.com/catalog...vid=3&pcid=213
scroll down to the bottom:
20-12498545 GM LS1 Head Bolt Kit for single cylinder head, contains 4 M8 bolts, 2 short head bolts, and 8 long head bolts. $23.99
hope that's what you need?
Old Jun 13, 2006 | 10:36 AM
Joel_SS's Avatar
No, I need the bolts that hold the intake on, not head bolts.
Old Jun 13, 2006 | 10:41 AM
Tech Resident
oh ****. good thing i read.
lol that's the line i read. why i did that, i have no idea since you were nowhere near the manifolds
http://www.thunderracing.com/catalog...vid=3&pcid=177
scroll to the very bottom.
113-430-2001 ARP LS1/LS6 Hex Stainless Steel Intake Manifold Bolt Kit $39.99
Old Jun 13, 2006 | 11:15 AM
Joel_SS's Avatar
Cool thanks!
Old Jun 13, 2006 | 12:08 PM
BADFNZ's Avatar
If you just need one and live around Coppell, you can come over and I'll give you one.
