Is it worth it to install LT headers from MACs?
Old Jul 8, 2006 | 10:53 AM
fastGBcamaro's Avatar
Default Is it worth it to install LT headers from MACs?
Right now I have all the boltons plus a TRex cam. I am going to be installing a set of ported heads and a FAST 90mm intake and TB in the near future. Would I see significant gains switching to LT headers. I realize that most of you will say yes, but I dont know anyone that has MACs that is disapointed, and many of them are making decent power. So would it be worth the swap?
Old Jul 8, 2006 | 11:54 AM
dug's Avatar
dug
I would. The macs run outta breath 6k and up. Thats where your set up makes most of its power. Pacesetters and Edelbrock headers are cheap.
Old Jul 8, 2006 | 01:42 PM
Gary98Z's Avatar
From what I remember reading, you may or may not gain much peak hp, but you will gain about 10rwhp or so under the curve, which is pretty decent.
I'd do it. Besides, after getting everything done and you don't swap to LT's, you'll always wonder...what if?
Gary
Old Jul 8, 2006 | 07:16 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Same here, swap them for some LT's.
Old Jul 8, 2006 | 07:34 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would do it. Purely for the fact that you can sell the Mac's and get LT's even cheaper.
Old Jul 8, 2006 | 10:27 PM
00scss's Avatar
I went from mac's to QTP's with the hvmcs. I didn't personally dyno before the swap so I can't tell you numbers, but it was a noticable difference. I'd go for it.
Old Jul 9, 2006 | 02:52 AM
HD1911's Avatar
i put on MAC ceramic coateds and ory today and love it to death....all you will give up to the lt's is a little torque on the bottom end due to not having a collector like the lt's do
Old Jul 9, 2006 | 08:49 AM
gillbot's Avatar
I spin mine to 6800 and my dyno graph kept climbing to almost 6500 with MAC headers. I don't see how they run out of breath at 6000?
Old Jul 9, 2006 | 10:25 AM
INMY01TA's Avatar
I think if you grind the welds down that stick out into the primaries you wouldn't see too much peak gain.
Old Jul 9, 2006 | 12:02 PM
gillbot's Avatar
I ported both mine and my wife's before I installed them.
Old Jul 9, 2006 | 12:15 PM
Frosty's Avatar
People still have the idea that anything aside from LT's=junk.
Old Jul 9, 2006 | 12:24 PM
8GTOKLR's Avatar
the only down side i would say is the are really close too steering shaft that combined with loose engine mount =headers hitting shaft. Secondly they dont just slide in you might have to coerce them a little. Oh and you might need new air tubes if the headers are for 98-02,I had to go to GM and get A.I.R tubes from a 98 model year, if you do get new ones get them for 01-02 specific
Upside they work really well i notice huge difference in accel, in ground clearence, thier catted cermaic Y bolts on which makes it nice. besure to use the stock steel LS1 gaskets all others dont even match the ports. Plug changes are easier too.
Old Jul 9, 2006 | 12:43 PM
gillbot's Avatar
this can happen with any brand of header though, LT or not.
You have no idea how many PM's i got after I posted the dyno graph of my car. Seems most dont want to or refuse to believe you can make good power with MAC headers.
Old Jul 9, 2006 | 02:31 PM
BTLFEDSS's Avatar
I saw no gain really going from my mac to LT's just different sound
BTLFEDSS
Old Jul 9, 2006 | 07:38 PM
Destru6969's Avatar
I don't know if there really is much difference between Macs and LT's, but I'm going to find out this weekend when my PaceSetters come in
Old Jul 10, 2006 | 01:27 AM
AINT SKEERED's Avatar
I gained 5 hp peak but with a little better curve with the Edelbrock lt's with the merge collector over the macs . The longtubes with the stepped design gave me a better deeper sound though. Not to bad though considering I sold my macs for 300 and only paid 450 for the Edelbrocks and y pipe .
Old Jul 10, 2006 | 12:29 PM
Studytime's Avatar
They don't. In theory a shorter tube will scavange best as RPM rises. This is similar to longer tubes scavaging better at lower RPM (which is why they make more torque).
If you "port" the tubes and do the collector mod there are certainly not going to run out of breath.
Ben T.
Old Jul 10, 2006 | 12:31 PM
Studytime's Avatar
Yeah, PREDATOR-Z has macs on his 370ci iron motor. Makes me feel better about mine.
Gillbot, what did you open the tubes up with? Just a carbide burr?
Ben T.
Old Jul 10, 2006 | 04:19 PM
dug's Avatar
dug
Ben T.
That is true but I think the 2.5" ypipe is a restriction as the power goes up.
I dont know either. I figure if hes running a big cam and fast intake why not get better headers?
Old Jul 10, 2006 | 05:43 PM
gillbot's Avatar
Ben T.
I used a carbide bit to rough them in then a fine diamond stone to "polish" them off.
I understand that people think the 2.5" Y is a restriction but running an open exhaust on that 2.5" Y will flow PLENTY of power IMHO. For me specifically though, I got the MACs because I like their fitment alot better than the LT's. Granted, I may give up MAYBE 5HP but I can live with that so I don't scrape on pebbles in the road.
