those with dumped duals in here
Old Jul 20, 2006 | 09:33 PM
slowscott's Avatar
Default those with dumped duals in here
Will aiming the dumps outwards help with the resonation at ~1500? Mine make it sound like a honda is chasing me for about 200-300 rpm on slow take offs.
thanks
Old Jul 20, 2006 | 09:38 PM
lastcall190's Avatar
I have 'em angled out about 30*... I have the same sound you describe, but other than that, I can't complain, and IMO it's quieter than my LM was. Try a 45* angle and see if that helps.
-J
Old Jul 20, 2006 | 10:01 PM
black_knight's Avatar
Make sure it isn't your trunk cover thingy rattling.
Old Jul 20, 2006 | 10:54 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Dumps = rattle
That is just a fact.
Old Jul 20, 2006 | 11:41 PM
Originally Posted by orangeapeel
Dumps = rattle
It's not the dumps that rattle. It's everything that's loose in your car. I don't have anything loose, so I get no rattle.
Old Jul 21, 2006 | 05:06 AM
slowscott's Avatar
Maybe it could be something rattling but i could swear it was the actual exhaust noise. I'll have to ask someone if they can hear it fromt he outside.
Old Jul 21, 2006 | 07:45 AM
Ls1_axxxman's Avatar
Mine does the same kinda thing, its just the nature of the beast. No matter how you angle em, you're gonna get some resonation.
Old Jul 21, 2006 | 07:47 AM
s346k's Avatar
mine don't do it.
perhaps muffler placement helps?
Old Jul 21, 2006 | 07:55 AM
ClemsonT/A's Avatar
My duals dont make any sound that sounds even remotely close to a honda. I do have some rattles but I need to go under there and tighten things up a bit.
Old Jul 21, 2006 | 08:01 AM
Fenster's Avatar
100% agreed. Of course I have Flowmaster Delta Flow 1 Chamber mufflers... so... yeah
I do get some resonance in the car about 1900 rpm for a split second if I am slowly accellerating in 6th gear, but thats it...
Old Jul 21, 2006 | 08:44 AM
DirtyJohn's Avatar
I'm guessing the effects will be minimal, but ive always had mine turned out.
And yeah, i get that too, maybe not at that exact RPM range, but close.
I think its a frequency thing of the pulses, and unless you get the resonation out from under the car completely, its just gonna happen.
Old Jul 21, 2006 | 06:27 PM
For the record, my setup has no rasp and has magnaflows with turn-ins. But if I leave that flap that covers the trunk down, it rattles with a very raspy sound. I leave it up for now, but I'm going to get some foam or something to shut it up. If I were you, I'd seriously look at something loose causing your noise. If not something in the car, then a loose heat shield or bad hanger. Duals should sound smoooooooth.
Old Jul 22, 2006 | 08:40 AM
slowscott's Avatar
I think i narrowed it down to one of the passenger side primaries being extermely close to the body. Hopefully I'll have time to do some hammering today.
Old Jul 22, 2006 | 07:34 PM
white_camaro's Avatar
angling the pipes at a 45 degree angle definately helped with my resonance and rattling. I also think it looks better, more professional.
Old Jul 22, 2006 | 09:07 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That was my point. Just in a shorter set of words.
Old Jul 23, 2006 | 04:24 AM
Azhigher's Avatar
Angling helped for me.
