F@&*#^% Car Won't Start After Header Install. HELP!!!
I recently installed Kooks LTs with ORY on my 2000 Z. Along the way I changed the motor mounts threw out the EGR and AIR, changed the oil, the Thermostat, changed spark plugs and wire, and did a TB bypass.
The long and short of it is that the car will now not start, it turns overbut doesn't start.
Things I have checked: crank sensor, battery, alternator, starter, gas and fuel pump, all wires (the only ones that are not connected are the two that are left from removing the AIR and EGR; one on the driver's side and one on the passenger's), also I checked some fuses.
Finally I got a spark tester, and when I tried starting the car it didn't seem like I was getting any spark (i.e. my friend nor I saw and spark passing through the tester when the other was attempting to start the car). So WTF is wrong what did I do/not do, I am pretty sure he spark plugs themselves are good (they are new). How do I get my car to run? I am so pissed I spent the last 5 hours in swelttering TX heat checking all the f***ing wires and other miscellaneous items. Please help, I would really like to get my car running again.
Your help is greatly ppreciated as always.
Like I said earlier it seems the problem is that I am not getting a spark, and I am pretty sure the wires or at least the ones I tested were well connected to the coil packs at the time of the test.
2001 NBM: don't really know anyone with a scanner in this area, I just moved here for grad school. There is some sort of get together for a local car club tonight I'm going to check that out and see if anyone there has one.
Make sure that thing is plugged in on the drivers side head, and reset the PCM.
To reset the PCM turn the key on, pull the PCM IGN and PCM BATT fuses in the engine bay fuse block.
let it sit for 10-15 mins with the key still on.
then turn the key off
and put the fusese back.
then try to start it, hope this helps!
EGR is plugged.
Engine temp sensor is plugged in (as long as thats the one right by the #1 spark plug).
Will try resetting PCM using those steps.
Is the crank position sensor the one that's right across from the starter, plugged into the tranny?
Thanks for the help and keeping it coming guys.
Basically the starter doesn't need to come off to get to the crank position sensor, correct?
So I guess i am now just awaiting clarification on where the crank position sensor is located.
Thanks for all the help, and kep it coming.
PCM reset.
Car still own't start.
Any other reasons that you can think of for why I am not getting spark?
Have yet to do the crank sensor, I don't want to shell out 40 bucks for a part that i am not even sure is broken.
PCM reset.
