Any downsides to an Electric Water Pump (EWP)?
Ok, fine, time to upgrade, right?
I've read the electric ones are supposed to be more robust & 5-7hp.
I use my TA street mostly, and a daily driver in the summer months, I assume the Meziere street version is my best choice?
Also, aside from wiring for the install, what are the disadvatages of the EWP? Any added noise?
Thanks all.
But, I didnt realize the limited life span 3000-5000hours!
When an EWP gives out, what happens - the car just starts to overheat?
Unlike the stock pump that will just leak and give out slowly?
Hhmm, If I pass on the electric pump, what would be a good choice for a replacement? stock, generic (auto zone), or what?
It would be like taking your pulley off of the stock water pump..
i would also only put one on if it wasnt the DD...DD duty is too much for the EWP and its relatively short lifespan
do the math. Even at 2 hours per day, for 5 years thats only 3650hours. Really not that much, I dont know anyone who drives their car 2 hours a day, 365 days a year.
I use the Evans unit, with the Evans NPG-R waterless coolant, 160 deg stat, SLP HD rad, ASP UD pulley - never any overheating problems - keeps the car cool no matter how much I'm on it or the outside temp. Plus you have the piece of mind knowing that it will not fail without prior warning.
BTW, I had originally purchased the Meziere Electric Street pump - had second thoughts about running an electric pump on a street car - sold it and went with the Evans unit.
An electric pump will afford you more flow at idle and low rpm conditions over a mechanical unit - but falls short of a mechanical unit after that as the electric versions run at one speed continuously.
-Jay-
-Jay-
