View Poll Results: Over or under the axle?
Over
52.83%
Under
47.17%
Voters: 106. You may not vote on this poll
Old Aug 21, 2006 | 09:07 PM
BLASTER's Avatar
Default Over or under the axle?
Want to finish the exhaust and get some tail pipes on to the car. Have my NJ inspection coming up and need to run out the back.
With going over the axle, I am worried about the tight drivers side, bang the axle or body and roasting the fuel pump wires
With going under the axle, I am worried about clearance, hitting stuff, and bottoming out
So which is the lesser of two evils?
Also, it worth mentioning that it's too late to run both pipes up over the passanger side as I already have invested in the side-by-side setup. Can't redo what's already done
May lower the car in a year or so. Springs have been already waiting a year to go on, so who knows if I'll ever do it.
Let me hear some good and bad stories.
Thanks,
Old Aug 21, 2006 | 11:12 PM
JEB Garner's Avatar
Run both pipes down the passangers side, go over the axle. There is roon for the two pipes (2 1/2 inch pipes). Then run both pipes out the rear in the stock location.
Old Aug 21, 2006 | 11:17 PM
Tainted's Avatar
^^ what he said. 2 1/2 inch pipe is plenty unless you got one hell of a car. both pipes go voer drivers side like a cat-back. if youre worried about banging BMR sells a panhard rod lecoation kit that allows you to run 2 3" pipe so that shoould solve any clearanc eissues you may be afraid of. also gonig over the axle gives you more ground clearance
Old Aug 22, 2006 | 01:13 AM
BLASTER's Avatar
Too late for that now. Can't redo what's already done. Edited post to mention that.
Old Aug 22, 2006 | 10:08 AM
67SS&99SS's Avatar
I have mine under the axle. I have yet to bottom out on anything. As long as the pipe is higher than your differential housing, its not going to scrape/bottom out the pipes. Here is a picture of what I have.
True duals under the axle.
Old Aug 22, 2006 | 10:30 AM
slow67's Avatar
Gingervitis Addict
I would go under the axle. See the end of the True Duals Sticky for my pics. Its a lot cheaper, easier, and should flow a lot better. I have yet to have my axle drop down and slap the exhaust.
Old Aug 23, 2006 | 07:03 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I went over, and it seems like it was a hassle to do any kind of work on the car. Looks better in my opinion though.
Old Aug 23, 2006 | 07:51 AM
staringback05's Avatar
could just dump it before
Old Aug 23, 2006 | 08:35 AM
TORCHD 02 TA's Avatar
i have posted pics in the TD sticky bottom of pg 4, also i made post here too on the external Engine section jsut do a search on my name and look at my pics.. BTW i went under the axel
Old Aug 23, 2006 | 10:01 AM
02SS:ZEUS's Avatar
I went over the axle, but I'm not sure if its even possible to go over the drivers side. I've never seen that. There are pics of my exhaust on page 2 of my car domain site in my sig.
Old Aug 24, 2006 | 02:52 PM
TheBlurLS1's Avatar
That's what she said...
You know how I roll......
Actually I have a Y-pipe now.
Old Aug 24, 2006 | 02:56 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
traitor.
Old Aug 24, 2006 | 03:01 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
then you haven't seen mine yet.
Old Aug 24, 2006 | 03:13 PM
TheBlurLS1's Avatar
Originally Posted by orangeapeel
traitor.
I've still got the duals on my backporch, so I haven't fully cashed in yet.
Old Aug 27, 2006 | 11:53 AM
BLASTER's Avatar
Got any pics of the clearance over the axle. I responded in your thread.
I dig your cutouts and always wanted some after my X pipe.
Old Aug 27, 2006 | 09:56 PM
Jefro6996's Avatar
I say go over the axle. I have kooks headers and true duals over the axle all the way back to the tips. 3'' all the way and both pipes goes over on the passenger side. I do have the bmr upper panhard bar and relocation kit for the lower panhard bar which gives more room. But i can even lower my car another 1.5 inches and still have clearance. I woudlnt do it any other way.
Old Aug 28, 2006 | 04:06 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
over...under looks backyard/cheap/homegrown..[although nothing wrong with homegrown.]....
Old Aug 28, 2006 | 06:46 PM
BuBbABFP's Avatar
Under.. i think if done correctly they look good.
Old Aug 28, 2006 | 07:10 PM
sunsetta's Avatar
Over the axle.
Old Aug 28, 2006 | 09:50 PM
NHRAMAN's Avatar
Question
Looks SILLY under. did you or are you thinking of putting a roll bar/cage on the outside of your car also.???
