A problem in slp`s C.A.P
Old Aug 31, 2006 | 06:33 AM
SUPER_CHEVY's Avatar
Question A problem in slp`s C.A.P
I just get my slp cold air package last weekend...
when just started install it i got a problem.. my car has a B&M trans. super cooler and i can not install the cold air induction(21033) b.cause there is no place for it..it should fit in the cooler place..(the cooler is installed in front of the a/c condensor)
who can i solve it???
and it is almost impossible to put them both in the a/c condensor the cooler is big to be there..
i must put the cooler in another place..
is there is some one had the same problem..or know how can do it!!
Old Aug 31, 2006 | 10:27 AM
radz282003's Avatar
If you are set on using that package, I would consider removing the plastic baffles, in front of the condensor and consider removing and replacing the washer bottle with another one. I had done both, and relocated the bottle below the left headlight.
The reason I did this was to remove obstructions from the front of the condensor/radiator. I have two 24K B&M coolers, and after getting tranny and coolant guages, and saw that I was getting coolant temps' up to 230+*and tranny temps' near 200*, in stop-and-go traffic, in my 45 minute commute, with the A/C on. After removing the baffles, relocating and replacing the washer bottle, and hanging both coolers off the back of the bumper bar, my coolant temps wouldn' t go above 215* under the same conditions, and my tranny temps' rarely get above 180*, even after several passes at the track. On the street, it will stay closer to 160-175*.
Some may say the tranny temps' are a little too low, but, I' d rather trade that off, and keep my coolant temps' under control. I change my tranny fluid regularly, and have not found condensation, or anything like that so far.
Good luck.
Old Aug 31, 2006 | 11:33 AM
jimmyblue's Avatar
Moderator
I butchered my SLP CAI for this same problem, but
if you want to leave it intact then relocate the
trans cooler ("Dope" style, or your own, get it off the
main stack). Personally I had poor results off the SLP
CAI as far as IAT readings, they went up big time
relative to using the SS hood alone. You might want
to glue some thin insulation board to the interior to
cut the heating of the air by that stainless heat
sponge. I reworked mine to draw from above the
divider panel (being as SLP required me to have
already hacked that open) and only have about a
2" stub of the original piece left but it makes a swell
base to pop-rivet alternative plastic ducting to.
No pics, sorry....
Old Aug 31, 2006 | 10:56 PM
thanks guys for ur great ideas...
but i wanna use them both...just wanna relocate the cooler..is there another place for it??
i need some damn pics
peace
Old Sep 1, 2006 | 07:19 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
SEND THE SLP PARTS BACK. All you needed was a lid and k and n filter. Nothing else.
Old Sep 1, 2006 | 09:38 AM
sickws698's Avatar
lol i agree with urban legend
Old Sep 1, 2006 | 11:36 AM
jimmyblue's Avatar
Moderator
I disagree with the K&N bit but in general,
Suckers Lose Power.
Old Sep 1, 2006 | 07:05 PM
Suckers Lose Power.
That is cool. But I bet you agree on the metal part being a POS.
Old Sep 1, 2006 | 07:35 PM
jimmyblue's Avatar
Moderator
Yeah, a CAI piece which raises temps is negative value
even at used prices.
