opinions needed on mods install
i accumulated the following:Heads/Cam swap with supporting mods
Headers and true duals
Pullies and tensioner
Injectors
Motor Mounts
Plugs/Wires
Rod Bolts
Shocks/Springs... and some other stuff that goes on other parts of the car
my question is since these mods are going in all at once, would you guys drop the whole subframe, or would you leave the block in the car? i have a 4-point chassis lift so i thought the subframe removal idea wasnt such a bad idea since i've never done a heads/cam swap and the mounts and rod bolts are gonna be a pain. what do you guys think?
If you were doing torque converter/clutch also I'd say pull the engine out.
Injectors
Motor Mounts
Plugs/Wires
Rod Bolts
this is actually a good idea !!! The Best V8 Stories One Small Block at Time
as for the tune, the car will be getting a base tune before i start ripping it apart so when all is done i can start it right up and be happy
i think i will be dropping the motor just cause i am fat and have a big head and its harder for me to squeeze in the engine bay of a f-body. the trans needs a rebuild too so while its out of the car i might just have t56rebuilds do their stuff.
i feel like a kid again
