Is This A Header Leak?? Pics And A Vid Inside
the reason i am saying this is b/c today i noticed that my lifter tick was louder than normal! and i poped the hood and i saw that the 3rd and 4th primary on the drivers side LT was some rust where it bolts to the head
HELP
ok first the vid.. Yes it is completly black welcome to almost winter here in chi town. it was 7:15 when i took it.
the first 10 sec was the camera right by the Trans Am logo on the drivers side door.
10 sec - 25 sec was on top of the motor.
the rest was in the same spot as the first 10 sec little more under the car..
what do yoyu all think???
pics are below of the rust. is the rust the sign of condesation???
What you are hearing is just the exhaust valves closing and normal exhaust sounds. When you switch from the cast iron manifold to a stainless steel header (or any steel header) you lose the sound dampening that cast iron gives. Different metals will resonate sound differently. Also, the stock manifolds are probably thicker than the header, so that also helps to insulate the sound.
Case in point, take a 6.0L iron block vs. a 6.0L aluminum block with the same exhaust. The aluminum block will sound much different than the cast iron block. Each metal has different harmonics.
anything else??
it does have the ticking sound to it.. did you notice that your car was louder when you were stopped?
the sound thta i recorded, what does that sound like to you???
you are right i worry. sounds like my motor will blow lol.. will going back to the M1 5W30 quiet it down a bit????
what is the rust from?
my buddies 02 z with Kooks LTs. his car does not sound like that at all...
Changing back to Mobile 1 will only make the valvetrain noise louder. I switched from Mobile 1 to GC a couple weeks ago and it quieted down the valvetrain racket a ton.
I would'nt worry about it, if it runs good, no loud ticks, is'nt knocking...don't sweat it.
I was the same way when I put my LTs on, it sounded MUCH different than before, and I did'nt have anything to compare it too. The guy that tuned the car said it sounded ok, and it runs ok, so whatever, I'm not going to worry about it.
what else??
The sound does not sound out of the ordinary. As The Alchemist said, your headers are simily amping the sound out your exhaust valves. However like I told you on the phone, when I ran 0w 30 my engine noise got louder, and then I switched to 10w30 and it made a difference.
m1 5w30 is thinner than gc 0w30, it's not your oil. You probably were not really paying attention to valvetrain noise during the exciement of the new headers. When I changed to longtubes, I also noticed it, as other people have said they had as well. I also can literally hear the air rushing through them when I really get into it. Thin walled tubular header ARE NOISIER.. and you are going to hear more engine noises period.
yea we have had some rain, but the pass side head/header is fine..
Jay, isnt 10W30 to thick for our motor????
i see what you are saying.. and i was paying attention to the noise b/c i had the radio off and i was listening to see if anyhting was hitting.. surely i would notice that lifter tick.. any new noise i pick up omn it right away i ahva radar ears LOL.. but like i said that noise showed up 2 days later.. has to be oil, or leak still. i will find out tonight
I listened to it, it doesn't sound like a header leak. It does sound a LOT like mine though.. I'm still banking on the headers.
after work went and bought M1 Fully Synthetic 5W30 and M1 Oil Filter jsut like i do everytime. Changed the oil let all the GC drain.... Filled it up with the M1.. Started it up and the car was SOOOOOOOOOOOOO MUCH MORE QUIETER!!!! yea it still has the lifter. just like it has alwyas had, but 100000 X quieter..
I will still check the LTs when i get the car in the air thursday, they are hitting the k member and vibrating the car drivine me nuts.. tonight i jsut jakced it up and was not really paying attention to the exhaust..
now my next question, yes it still ahs the lifter tick but is quieter, can i put some lucas stabilizer oil in ther to quiet it down even more? also when running the GC oil, was that bad for the lifters/motor??
again like i said, my car sounds like it used when i had manifolds on, but now it is a little louder prolly b/c with the LTs.. but nothing compared to when i ran GC for about 250 miles.
GC = CRAP
