will these flow enough?
Old Sep 17, 2006 | 07:19 PM
nodnarb481's Avatar
Default will these flow enough?
Im thinkin about getting two of these welded into my y-pipe will they flow enough for my setup?
http://216.178.81.107/iwwida.pvx?;it...0%201?comp=ppe
Old Sep 17, 2006 | 08:51 PM
iamsickofitall's Avatar
link isn't pointing anywhere helpful
Old Sep 17, 2006 | 09:11 PM
nodnarb481's Avatar
there ya go...
Old Sep 17, 2006 | 09:20 PM
TransAm_00's Avatar
Flows at 450.0 CFM
Weighs only 2.5 lbs
Stainless steel construction resists corrosion
High Flow design
EPA and C.A.R.B. legal (executive order D-567)
60,000 Mile Warranty
Here's all the specs for you.
Old Sep 17, 2006 | 09:22 PM
nodnarb481's Avatar
yea i read that.. but i dont know how much flow is good or anything. I know i have a magnaflow hi flow cat welded in the I-pipe because i had to get it done to pass emissions.. im told this chokes the engine because it cant flow enough and i need two cats in the Y because then they are only having to flow half the engine instead of all of it. So im going to get two mini cats to put in my y-pipe and i was just trying to figure out if they would flow good enough for what i have.. or even will they flow better then what i already have?
Old Sep 18, 2006 | 03:38 AM
300bhp/ton's Avatar
Check the sticky, post 13!
1hp requires 2.2CFM
Old Sep 18, 2006 | 05:51 AM
nodnarb481's Avatar
so then these would be good for close to 400hp.. i guess they flow enough. So is it true that the one cat i have now is choking my engine?
Old Sep 18, 2006 | 04:00 PM
300bhp/ton's Avatar
Old Sep 18, 2006 | 04:50 PM
nodnarb481's Avatar
thank you very much for your short too the point answers... i best get to shopping now..
