1998 LS1 Oil pressure sending unit
How do I remove the broken part of the sensor stuck down in there?
Also whats the different between the 98 and the 99-02 unit?
Anyone happen to have the part number of the 98 sensor on hand? Also, would the 99-02 sensor work?
I searched but couldn't find the part number.
thanks in advance!
SEARCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
you need a Oil Pressure sending unit socket.. sold for $5 at autozone..
if you're lucky.. you can also pick up the sending unit from autozone if they have one in stock, if not.. its a 3 day wait.. or go to a dealer..
If you would have read properly, I clearly stated that I needed to know the difference between the 98's and the 99-02. I searched before I posted and couldn't find anything on the 98 oil pressure sending unit.
Do I need the socket for a broken sensor?
ordered one from summit racing and the oil pressure sending unit was for a 00-02 which the tread diameter was too small.
the 98-99 is a bigger diameter
so make sure u get the correct year.
i ordered it from advance auto
