Rasp and Drone
Old Oct 10, 2006 | 03:50 AM
LSGunZ28's Avatar
Default Rasp and Drone
can someone clearly describe to me what these sounds are? I thought I knew, but now Im not too sure.
I always thought rasp is an annoying or a sloppy onboxious, ricer type of sound. such as a fart cannon on a ricer. and drone is a solid note a car has at a certain RPM that is annoying to hear, like a low tone buzz or so.
can someone clarify what Drone and rasp is?
while we are at it, what is throaty and deep and ricer and all these terms?
edit : I looked up the term Rasp or Raspy is a harch grating type of sound, yet people call the Loudmouth Raspy. I dont think that is what Rasp is.
I was correct about drone
and I am pretty sure throaty means deep and agressive type of sound.
Old Oct 10, 2006 | 04:14 AM
300bhp/ton's Avatar
In general people use them to mean absolutly anything. And the mojority of the time incorrectly.
Rasp and drone are both in the Oxford English Dictionary. However their use for describing LS1 exhaust notes is often bafferling.
Old Oct 10, 2006 | 04:21 AM
LSGunZ28's Avatar
for example. I have drone when I at 75 mph on the freeway in 6th gear ( slightly under 2000 RPM (3.42 final drive ratio) its a solid, deep note I hear ( kind of reminds me a 5.0s exhaust for some reason) anyways, that is drobe for you. but I dunno how to describe rasp. and I dunno how to describe LT + ORY + LM. but it just sounds nasty and sloppy/unclear.
Old Oct 10, 2006 | 08:21 AM
BrandonDrecksage's Avatar
you can't define it, but when you hear it...you know it. It is sort of subjective though because some people like different sounds then others.
Old Oct 10, 2006 | 09:42 AM
monicaz28's Avatar
To explain raspy, listen to just about any Ls1 that is fast. lol It's like when the exhaust no longer sounds deep and rumbly, it becomes more high pitched and just loud. Mustangs have a deep rumble, Lt1's have a nice rumble, Ls1's are raspy... if they all had a similar exhaust with similar mufflers that is. Or another example, bullet mufflers are raspy, spiral mufflers are deeper sounding. And drone is the constant hummmm you would hear at higher speeds mostly with a louder exhaust or a cutout.
Old Oct 10, 2006 | 10:00 AM
JohnnyC's Avatar
rasp usually occurs when you let off the gas - kind of like a rapid, high pitched, crackling sound (think chainsaw). Drone is just the annoying, vibrating, resonating tones that you hear at constant RPM while on the highway.
Old Oct 10, 2006 | 10:42 AM
Cop Car's Avatar
rasp: straight pipes/GMMG/SLP loudmouth during mild acceleration, very sharp and hurts the ears, sounds like crap
drone: straight pipes/GMMG/SLP loudmouth at a constant crusing speed, its a constant bass inside the car that actualy hurts your ears
Old Oct 10, 2006 | 07:57 PM
LSGunZ28's Avatar
so will a dynomax bullet mellow down the rasp? I wanna just swap out the bullet muffler to a better one
LM II, Dynomax or what?
Old Oct 10, 2006 | 09:36 PM
Cop Car's Avatar
people say they like the bullets
my personal favorite is magnaflow mufflers
Old Oct 11, 2006 | 12:32 AM
LSGunZ28's Avatar
In 6 - 8 months, when I do a cam install. I will do a true dual install. Until then I want a quick solution.
WIll the Dynomax reduce rasp to a decent amount?
God I miss the way the LM sounded on stock manifolds.!
Old Oct 11, 2006 | 01:04 AM
RrCoX22's Avatar
true duals will basically give you no rasp/drone as its the best sounding exhaust IMO... most of the time rasp/drone is overplayed IMO
Old Oct 11, 2006 | 09:09 AM
monicaz28's Avatar
True duals do not alleviate rasp/drone. It has more to do with what mufflers you use than what exhaust you go with.
Old Oct 11, 2006 | 09:11 AM
monicaz28's Avatar
If you like something a little more mellow and quiet, but with a good deep sound, Magnaflow is a very good choice for sure.
Old Oct 11, 2006 | 04:54 PM
LSGunZ28's Avatar
what bullet reduces rasp more?
Dynomax?
Borla XR1?
LM II?
Old Oct 11, 2006 | 05:23 PM
farnoush's Avatar
rasp with LM usually happens between 2000 rpm and 2700 rpm under mild acceleration, only way I can really describe it is it sounds like a machine gun. For me it drones around 1700 rpm but doesnt bother me too much.
Old Oct 11, 2006 | 06:19 PM
2K2WS6TA's Avatar
For me rasp is like an old chevy pickup with glasspacks and dual pipes, that crackling sound it makes when it accellerates
drone is more of a steady tone, like a motorboat going across a lake
That's how I'd describe the 2 sounds
