ignition coils
Old Oct 30, 2006 | 04:22 PM
jakebdb56's Avatar
Default ignition coils
i've searched around a lot and have found info on all the different types of the genIII coils, I have a full set of LS1 coils that are the round ones. will they work definately on a truck harness? the harness is a 2002 from a silverado. I just want to know if someone has tried it and it works, I dont see why they would be much different... Iguess I could go try one on my truck later if no one has a response. btw the harness is going into a sandrail, so I cant really test the harness with the coil since I dont have it hooked up yet.
thanks,
jake
Old Oct 30, 2006 | 05:52 PM
jakebdb56's Avatar
cmon, I know someone has to know
Old Oct 31, 2006 | 07:59 AM
00454sscamaro's Avatar
acourding to everything ive read the one (round i think, dont have the book in front of me) type of truck coils are the best type.. so i think the coils are interchangable.. not sure though.
Old Oct 31, 2006 | 08:22 AM
oange ss's Avatar
as long as they're not LS2/LS7 coil packs they will plug in
Old Oct 31, 2006 | 10:27 AM
Cerebrex's Avatar
They should work if they are LS1 coilpacks.
Old Oct 31, 2006 | 12:45 PM
jakebdb56's Avatar
good deal, im almost done gathering parts for the LS350, got the pcm/harness on the way now. all I gotta do now is fab the intake and sensor adapters.
thanks for the help
Old Nov 7, 2006 | 08:12 PM
WILWAXU's Avatar
If you need future help with the project, hit up our Conversions & Hybrids section. Those guys might be a little faster to respond.
Old Nov 7, 2006 | 09:42 PM
under pressure's Avatar
I believe the LS1 and the early round truck coils are very close performance wise, however their connectors are different. As long as your wire harness matches your chosen coil you should be OK.
Old Nov 8, 2006 | 12:39 AM
jakebdb56's Avatar
yeah I just found that out the hard way lol. is there any way to convert the coil harness to be used with the ls1's?
Old Nov 8, 2006 | 12:41 AM
jakebdb56's Avatar
thanks for the help, we're getting close to actually installing stuff on the buggy
