Exhuast options
I had a Pacesetter with TSP X-pipe swet thunders, and it was o.k until I got the MS3 Cam then it was extereme after that and I loved it, but had 2 drive very carefully, Cops are noise **** here in C.A., also do u plan on gettin a cam? if so wat size? Cause that well make a difference in wat u might want
R.I.P Blk 99 Z28 A4
Lid, Pulley, Pacesetter LTs, TSP X-pipe sweet thunders, refurbished vig 3800 stall, 3.73,LS6 manifold, Trans cooler, and MS3 cam. 11.5 @119MPH
Next Z comin summer of 07
R.I.P Blk 99 Z28 A4
If you want good sound plus good performance then u cant go cheap, I would suggest Borla, or Corsa. Borla has a meaner side and defeitly noticable. But I personally Like corsa. Not as loud but if ur gettin a cam and don't want it insanely loud but still mean and muscular and noticable. Corsa's exhaust look is 1 of my fav's.
R.I.P Blk 99 Z28 A4
Now if you are weary that is is too loud, that is another story.
For options on a y-pipe and catback, if I were you, I would have a custom ypipe made with a good 3" collector, and have it run back to a Magnaflow muffler purchased separately. It would be the same as a catback ypipe setup, but since it would be mostly custom made (and easy to make) it would cost a lot less fortunately. Plus Magnaflow has a nice refined sound to it, that doesn't cost any hp.
You could search the for sale section also, and look for a used Magnaflow catback, to go with a custom ypipe. There are other catbacks that are just as good, but I like Magnaflow because of the refined sound and musclecar nice sound it has, plus good performance. Even a new Magnaflow catback doesn't break the bank very much and is very affordable.
As another option, you could have your current true duals custom run out the back, which would be less loud, but you need to find someone good at mandrel pipe bending for that.
Of course if you have disposible cash you could always get a QTP ypipe and Magnaflow catback but that would be much more expensive and not perform any better than a custom setup. I would run a custom setup with a Magnaflow muffler and a flowmaster collector, best performance out of a ypipe catback setup for not a lot of dough.
It's not too loud for "civil" driving, but WOT, it's f^&*ing awesome.
