good poly mounts
Old Dec 9, 2006 | 02:00 PM
SUCK MY SS's Avatar
Default good poly mounts
well i ordered a set of pacesetters and the tsp rumbler TDs and while im puttin em in id like to change the motor/tranny mounts out with poly pieces....what would be a brand to choose that is good quality and not too heavy on the pockets
Old Dec 9, 2006 | 02:23 PM
JPH's Avatar
JPH
i use prothane myself. good quality and the fit perfect.
Old Dec 9, 2006 | 02:30 PM
bww3588's Avatar
Prothane motor and tranny mounts and energy suspension torque arm mount.
Old Dec 9, 2006 | 03:33 PM
TheBlurLS1's Avatar
That's what she said...
Prothane stuff for motor mounts on my car. I have "energy suspension" tranny mount. Check thunder racing's "Bushings" section.
Old Dec 9, 2006 | 11:03 PM
DOUBT IT's Avatar
This setup +1. I have a pinky finger's clearance between the driver's side pipe of the duals to the brace under the driver's seat and have ZERO problem with the pipe hitting.
Old Dec 10, 2006 | 01:24 AM
BriancWS6's Avatar
Using an Energy Suspension trans-mount here as well.
Old Dec 10, 2006 | 03:41 AM
Rob98LS1's Avatar
I use prothane engine mounts, they have worked great!
Old Dec 10, 2006 | 08:41 AM
01SLPSS's Avatar
Have The Energy Suspension Tranny Mount on the Car and Will be Installing The Prothane Motor Mounts When I Do My Header Install Soon!!!
Old Dec 10, 2006 | 10:05 AM
SUCK MY SS's Avatar
so why did some of you guys opt for prothane motor mounts but energy tranny mounts?
would it be a good idea to replace my torque arm bushing while im down there?
the only reason i ask is cuz sometimes out of nowhere the car will start clunking everytime i shift gears or hit the brakes...then as suddenly as it comes it goes away until the next time it pops up....common sense would say the exhaust hitting, but wouldnt the exhaust hit all the time, not sometimes for a day or two then dissapear for a few weeks then start bangin again for a couple days? now when i was doing my LCAs/brackets, i took a look under the car and it looked like the TA bushing was kinda going to crap, as well as there was grease covering some of the components...where did the grease come from?no big deal? i can take flicks if it helps...
Old Dec 11, 2006 | 11:02 AM
SUCK MY SS's Avatar
anybooty?
Old Dec 11, 2006 | 09:24 PM
DOUBT IT's Avatar
Ordered the Prothane motor mounts because Thunder had them at a good price. Put the Energy Suspension Trans Mount on because I broke the stocker and needed one quick. Got it from the local speed shop.
Old Dec 11, 2006 | 10:19 PM
wht01ws6ta's Avatar
+1 Went from terrible thumping after LTs to 0 thumping after poly mounts install
Old Dec 11, 2006 | 11:18 PM
SUCK MY SS's Avatar
how was the in car vibration?
Old Dec 11, 2006 | 11:25 PM
DOUBT IT's Avatar
It's not that bad so long as you don't use the plate that comes with the mount. Grinding down the little "bumps" is up to you. I didn't and have no real vibration from the mounts. Now the vibration that I get from the wheels, that's another story.
Old Dec 11, 2006 | 11:46 PM
SUCK MY SS's Avatar
whats up with your wheels? need a balance or something?
why would i not wanna use the plate? theres gotta be a reason for it
Old Dec 12, 2006 | 12:15 AM
DOUBT IT's Avatar
Nah, either I need hub centering rings or I need new lugs. Somethings off.
Because it shifts the tailshaft of the tranny up too high, and causes vibration due to misalignment. In short, with the plate, it's too tall. The plate makes a good paperweight though.
Old Dec 12, 2006 | 01:05 AM
SUCK MY SS's Avatar
oh ok....i wonder why they havent addressed the issue yet....well the pep boys down the street from the shop said they can have all the mounts within a day....but they are all from ES....what do you guys think about the ES motor mounts...id order prothane from summit, but it sucks not having a credit card...oh well
Old Dec 12, 2006 | 02:31 AM
bitterchaos's Avatar
What plate? I just got my mounts and there arent any plates in the box
Old Dec 12, 2006 | 02:33 AM
Rob98LS1's Avatar
I have heard great things about the ES trans-mount, so I just ordered one today. I'm sure it will go well with the poly motor mounts.
Old Dec 12, 2006 | 11:43 AM
SUCK MY SS's Avatar
the tranny mount has a plate not the motor mounts...
anybody have experience with ES poly motor mounts
