ORY for Stock Manifolds...Help
Old Dec 12, 2006 | 08:10 PM
StillUnnamed's Avatar
Default ORY for Stock Manifolds...Help
I'm looking for a ORY that hooks up to the stock headers. I'm not looking for alternative options like LTs. Just looking for this if there is such a thing. Thanks, - JScott
Old Dec 12, 2006 | 08:38 PM
staringback05's Avatar
just find one that fits shorty headers.....
2_wacko's Avatar
I've never seen one, but you could have one custom made.
Old Dec 12, 2006 | 08:46 PM
Starz T/A 17's Avatar
yea thunderracing sells them, or you could just gut your cats and get O2 sims
Old Dec 12, 2006 | 08:49 PM
RrCoX22's Avatar
custom would be a good route for that as it's not all that common of an exhaust setup
Old Dec 12, 2006 | 09:13 PM
Yea its goin to be just like you gutted the cats so you will probally gain 5-10 HP and it will be alot louder
Old Dec 12, 2006 | 09:20 PM
SSTYCOON's Avatar
mac makes a ORP for stock manifords...
Old Dec 12, 2006 | 09:21 PM
That's the idea son...
Old Dec 12, 2006 | 09:27 PM
SSTYCOON's Avatar
the mac ORP keeps the cats...you can gut them out if you like
Old Dec 12, 2006 | 10:36 PM
INMY01TA's Avatar
Not true at all. Mac does make an ORY for stock manifolds, only 98-99s tho.
Old Dec 13, 2006 | 08:47 AM
Humanoid's Avatar
SLP makes one.
Old Dec 13, 2006 | 09:26 AM
jimmyblue's Avatar
Moderator
They are out there, you might be better off with a
multi-piece setup like a SLP stock-cats Y (slightly
fatter, no crush) and "test pipes" if you are or you
expect to be under a smog regime anytime soon.
Full Y to the logs is going to be more work to swap
and unswap than the tubes. SLP Y sells for pretty
cheap, used and it's stainless. Mufflex tubes are
more rare but can be found. Together this is your
ORY, logs to I-pipe. Believe Bassani and somebody
else make a full stock-logs ORY though, if that's
your preference. I'd stay away from non-Mufflex
"test pipes", I picked up a pair once but they were
aluminized (not stainless) and did not fit properly
either.
Just the tubes, will give you most of the gain. On
a stock cam / stock logs car the Y is not your
biggest problem.
Old Dec 13, 2006 | 11:00 AM
BitViper's Avatar
The SLP manifold...
Mann..I keep changing my mind....Now this looks like a viable change..and only 200 bucks too boot.
Are their claims true (I know... I know) of more HP? Im assuming that their claim of 10 is at teh upper limits..
My plans are uto try to "Optimize" my car. IM not chasing HP nessiarilary..but will welcome any I gain.
My plans for my daily driver are/were in no particular order
224/224 cam
Port my stock TB
New exaust system
Under drive pulley
and change up to 3.73's or 3.90s
Jimmi..what are "Test Pipes" or are you saying that he should have a set of pipes specificly for testing?
And what are or is "stock logs "
Old Dec 13, 2006 | 12:46 PM
jimmyblue's Avatar
Moderator
Cast iron manifolds referred to as "logs".
Manufacturers call them "test pipes" because as we
all know, emissions tampering is illegal. So you would
naturally only be using these temporarily, until you
have made up your mind whether the cats were bad
(judging by change in performance). But it might take
a good while to make that determination. Like, up to
next years smog inspection. Can't rush to judgement,
now.
I got my SLP Y for like $100 used. No point buying
bent pipe at retail just because it's shiny. Let the guy
before you take the depreciation. BTW, I noted zero
gain (trap speed) from the SLP Y. Did see a bump in
Dynamic Cylinder Air values after cat gutting though,
which has to mean more power out. Which is why I
say the Y is not one of the more significant restrictors
on a basically-stock car.
Old Dec 13, 2006 | 01:00 PM
SSTYCOON's Avatar
you are right. I'm confused... the pipe i was thinking of was the one from slp. It's a larger y pipe that bolts on after the cats for a 00-02 fbods. I had it on my 01, I gutted the cats while i was there.. it was noticeably louder. cost around 200.00.
Old Dec 13, 2006 | 01:08 PM
pSSycotic's Avatar
I have a custom one. Its sittin in my buddies shop since I got my Lts up. Couple people are intersted inbuying it. Ill post pis when i can
Old Dec 13, 2006 | 01:14 PM
If you look at thunderracings website under y pipes they make MANY different kinds, ORY and ones that attach to your cats.
But if you get rid of the cats your going to be illegal so why not just get LT'S
Old Dec 13, 2006 | 02:33 PM
BitViper's Avatar
Thanks Jimi..learn somthing new everyday here!
Old Dec 13, 2006 | 03:47 PM
MonkeyBoneSS's Avatar
I have a Bassani ORY pipe, got it from Thunder. Its easy as hell to put on and increase over all sound, a bit
Old Dec 14, 2006 | 10:46 AM
BitViper's Avatar
now.
So your attributing your increase in throughput of air to cat gutting and not the SLP pipe
