Huge Exhaust Problems...please Help
Ok, now the fun part....today i went to get my cutout welded on and noticed that there are no cats on the exhaust....i also noticed that the only o2 sensor that was hooked up was the one on the drvr side before the cat (the one i replaced) someone has put in new pipe starting at the manifold and there is not even holes where the other o2 sensors go..........So , i have one o2 sensor hooked up, the drvr side front...........what do i need to do...whats the easiest fix...the car is idiling fine and i cant really tell that anything is wrong...
If the cats were deleted, previous owner probably just had the codes turned of for the rear 02 codes. If the light just came on for a precat sensor the code will tell you which side it is - you probably have a bad passenger side precat sensor? - get the code(s) read again and post'em. Trending Topics
You know adding LT's to your setup will provide a place for both 02 sensors, but that's kind of bypassing the original problem of why there isn't a place for them in the first place. However it's never a bad idea to go with LT's...but if you just want to fix your current exhaust, take it to a good exhaust shop and they can make a place for your other 02 sensor (drill and tap a hole for it...), the same as the other side. What are your mods? If you have a factory exhaust you probably don't want to go through the hassle of getting cats for it, until you go LT's, unless you need them for emissions, but I would go with LT's at the same time.
Usually the 02 bung for LT's is in the collector, for factory setups I believe it's NOT in the manifold itself but in the pipe after the manifold however someone else correct me if that's not correct.
It still might throw a code for rear 02 sensor after you get the front one installed, and it may run rich again with no cats installed, so you'll need a tune ($400-500) to correct it. Not necessary probably because theoretically that's why you have 02 sensors so it can correct for the right air/fuel ratio, but it's not exact.
Best bet for the least amount of money is have your exhaust guy put in the front 02 sensor, then see how it is. Check it out at that point and make a determination from there.
