need help...trouble code P0135
Old Dec 25, 2006 | 09:01 PM
highheat99's Avatar
Default need help...trouble code P0135
can someone please help me on what is causing this code to come on? thanks
Old Dec 25, 2006 | 09:23 PM
gman's Avatar
I am prettey sure you have a bad 02 sensor.
Old Dec 26, 2006 | 12:51 AM
matts22's Avatar
In HP Tuners, it says: HO2S Heater Performance Bank 1 Sensor 1
This means you have a bad front O2 sensor...not sure which one though, maybe someone else knows this. I know it is front though.
Old Dec 26, 2006 | 01:27 AM
TheBlurLS1's Avatar
That's what she said...
If you do replace them, use the Bosch 13111's. You can search to read more about them, and here's the place with the lowest price.
http://rep.speedycarparts.com/parts/...gory=C&dp=true
Old Dec 26, 2006 | 03:04 AM
matts22's Avatar
Just curious, but why do you suggest the 13111? It looks like those are for vette's and he has an '02 z28. Looks like he needs either 126270 for the front right, or 103374 for the front left. I could be wrong though...
Old Dec 26, 2006 | 03:28 AM
TheBlurLS1's Avatar
The Bosch 13111's are 'vette rear O2 sensors. They have a stronger heater, and longer wires. LT's on these cars cause O2 problems because the sensor is now so much farther downstream that it gets too cool and you get heater performance codes, or insufficient switching. You also need O2 extensions on the wiring harness on our cars. The 13111 solves both of these problems.
Old Dec 26, 2006 | 03:40 AM
matts22's Avatar
But the O2 extensions are for the rears, and so are these O2 sensors...he needs a front O2 sensor. Would this work as a front sensor as well? I'm interested in this now, since I have LT headers...
Old Dec 26, 2006 | 06:46 AM
highheat99's Avatar
yea i looked at the bosch but like mentioned already it says for the vettes. would this work on my 02 z28? would i need front or rear or does it matter?
Old Dec 26, 2006 | 06:51 AM
highheat99's Avatar
Default bosch
http://performance.speedycarparts.co...5&brandid=2654
would those work since they are for a camaro?
Old Dec 26, 2006 | 08:15 AM
OUTLAWZ RACING's Avatar
I have been running the bosch 13111 for years. they will work just fine no mods nessary just buy some zip strips those pig tales are long!!
