ls2 intake on ls1
Old Jan 10, 2007 | 10:02 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default ls2 intake on ls1
ok has anybody read the article in gm high performance about using the l92 heads off the escalade and the l76 intake off the holden its similar to the ls2 intake. but how do you convert the tb off the intake though to use by cable not by wire?
heres the intake
http://cgi.ebay.com/ebaymotors/2006-...QQcmdZViewItem
Old Jan 10, 2007 | 10:23 PM
greysteel_M6's Avatar
I've been wanting to do the same. Vette intakes have been by wire for some time and I believe those have been adapted to use on fbodies. Do the ls2's use 90mm tb's?
Old Jan 10, 2007 | 10:39 PM
HAMRHEAD's Avatar
LS2's use the 90mm throttle body and you will need to fab something up for the cable. However if you are N/A I wouldn't suggest using an LS2 intake. Go with a LS6. The LS2 is nice in FI setups but not the N/A ones.
Old Jan 10, 2007 | 10:45 PM
zspot98's Avatar
From eveything I've read, the LS2's flow no better than the LS6's.
Old Jan 11, 2007 | 08:01 AM
TT402LS1's Avatar
If you run a LS2 intake you will need a cable type TB. Street & Performance sells a throddle cable bracket for the LS2 intake.
Ron
Old Jan 11, 2007 | 03:46 PM
LS1Tech Sponsor
its not the ls2 intake though its actually an intake off a holden but it has the same type off throttle setup but the it fits the l92 heads its more like an ls7 intake
Old Jan 11, 2007 | 03:59 PM
Tainted's Avatar
just use an ls6 intake
Old Jan 11, 2007 | 04:19 PM
LS1Tech Sponsor
it wont match up to the l92 heads
Old Jan 11, 2007 | 04:23 PM
Tainted's Avatar
ohhh ok I see what yalla re doing now. I thought it was another one those why not a ls2 intake instead of a ls6
Old Jan 11, 2007 | 04:33 PM
LS1Tech Sponsor
no the l92 heads are off the 07 escalade, theyre based on the ls7 heads but run a fatter intake runner. so the ls2 and 7 intakes dont match up, so you have to use the l76 intake off the holden which uses the same tb as the ls2. the heads run about 850 completely assembled from gm and the intake including 39lb injectors tb fuel rail is about 500 bux but it has to be converted to work on and ls1 cable style throttle
Old Jan 11, 2007 | 04:36 PM
TT402LS1's Avatar
Call S&P. Maybe they have something for your setup. They seem to be right on top of things like that.
Ron
Old Jan 11, 2007 | 05:25 PM
TheBlurLS1's Avatar
That's what she said...
Most people run the standard 90mm TB (NW, PTM, UMI) on the L76 intakes I believe. This way you only need a bracket.
Old Jan 11, 2007 | 06:26 PM
LS1Tech Sponsor
if your talking about the ls1 tb there three bolts and the l76 are 4 bolts
Old Jan 11, 2007 | 06:28 PM
LS1Tech Sponsor
if your talking about the ls1 tb there three bolts and the l76 are 4 bolts and whos PTM
Old Jan 11, 2007 | 08:54 PM
TVWilkes's Avatar
The PTM 90mm billet tb is sold thru TSP.Excellent tb and at a very reasonable price.
Old Jan 12, 2007 | 03:52 PM
LS1Tech Sponsor
thanx guys
Old Jan 12, 2007 | 10:19 PM
MiaSSmaro98's Avatar
katech sells kits
Old Jan 13, 2007 | 08:35 AM
BigDaddyBry's Avatar
Originally Posted by MiaSSmaro98
katech sells kits
Ditto. This is where you want to look for your cable/fly by wire conversion.
Old Feb 22, 2007 | 12:47 PM
1SickWS6's Avatar
Do you have a part number for the cable bracket? I cannot seem to find it on their site..
Old Feb 22, 2007 | 02:08 PM
slt200mph's Avatar
It is a knock off of a Nick Williams throttle body
