Can this FAST 90 be fixed? (picture)
Old Jan 14, 2007 | 09:12 AM
Marc '99T/A's Avatar
Default Can this FAST 90 be fixed? (picture)
Old Jan 14, 2007 | 10:30 AM
KilerTA's Avatar
i think they if you get ahold of fast they might sell you the top peice i know my buddy did that when he cracked the bottom part of his
Old Jan 14, 2007 | 10:42 AM
Yeah, but I was trying to avoid that. The top piece alone is over $400. I was trying to see if I could put a fitting in there that would work.
Old Jan 14, 2007 | 10:57 AM
1cdub's Avatar
why not drill it out, tap it NPT and throw a barb X NPT fitting in it and roll...
Old Jan 14, 2007 | 10:59 AM
1fast01's Avatar
+1 on that...
Old Jan 14, 2007 | 11:03 AM
LARRY01Z28's Avatar
i third that. drill it. thats an easy fix. if you dont want to fix it ill buy it for 100 bucks. lol
Old Jan 14, 2007 | 11:24 AM
2000LS1TA's Avatar
I'll buy it from ya for 125
Old Jan 14, 2007 | 11:29 AM
I could definately do that, but where would I get the fitting? And what kind, "barb X NPT"? What exactly is that?
V6 Bird's Avatar
Sand it off...tap the hole for a npt type fitting with a barb style on the other end of it...Use a little bit of thread sealant and go to town!
Old Jan 14, 2007 | 11:30 AM
Ericbigmac83's Avatar
$150
Yea, you should be able to fix that.
Old Jan 14, 2007 | 12:03 PM
Twinki025's Avatar
And another rusty bolt i see. Sorry guys i had to say it
Old Jan 14, 2007 | 03:38 PM
1cdub's Avatar
you can get both the 1/4" NPT tap and the 1/4 npt x 1/4" barb fitting at any hardware store....the tap will usually have the size drill bit that you need to use printed right on it....good luck.
Old Jan 14, 2007 | 04:16 PM
Thanks guys, I was hoping that it could be saved.
Old Jan 14, 2007 | 08:09 PM
BADFNZ's Avatar
Fill it in and get rid of the EVAP system.
Old Jan 14, 2007 | 08:32 PM
oange ss's Avatar
easy fix, but dont get too aggressive with the drill bit , it'll get caught up and crack the housing
Old Jan 14, 2007 | 08:54 PM
Grimes's Avatar
keep the drill speed low, and use lots of lube!
Old Jan 14, 2007 | 08:59 PM
dpw41285's Avatar
slow and steady, you dont want to crack it
Old Jan 14, 2007 | 09:01 PM
I was thinking that, but I don't know too much about it. I was reading about it in a thread by erikthegoalie: https://ls1tech.com/forums/fueling-injection/635292-do-you-really-need-evap-system.html
I have a while to decide before I install it; (saving up enough for my AFR's).
good point
Old Jan 15, 2007 | 12:32 AM
35th SS's Avatar
or jb weld that bugga.j/k like everyone said.good luck
Old Jan 15, 2007 | 01:36 AM
TheBlurLS1's Avatar
That's what she said...
Plug it and delete it. That solenoid is fugly.
Originally Posted by MeentSS02
I deleted all of the codes, and took off the solenoid and plugged the hole in the manifold. I just run a piece of rubber hose off of the hard line under my fuse boxes and right around to where my fog light is on the driver's side. I put a small filter on the end of the line, and was done with it.
That's exactly what I did, but without the filter.
