Header questions
Old Feb 25, 2007 | 06:30 PM
motomike734's Avatar
Default Header questions
well finally i got my headers and ory on!! I unpluged all the egr and air and capped it off and soon hopefully make it down for a tune! My question is since i dont have it uned will it run like crap and be very poppy sounding. Just seems to be running rough
Old Feb 25, 2007 | 07:21 PM
LS1 ACE's Avatar
it will run like crap at first, until the computer adjusts itself. after that it will run just fine. if you tune it, it will definitely run better though. think of a tune as a fine honing process. if you have any popping sounds or noises check your spark plugs and spark plug wires. now go enjoy your new found power!
Old Feb 25, 2007 | 07:22 PM
i just put new plugs and wires in too along with the bbk intake all in the same adding
Old Feb 25, 2007 | 07:24 PM
RrCoX22's Avatar
if anything you'd just be running rich on your tables... but most people don't even tune after just a header install
Old Feb 25, 2007 | 07:25 PM
well i no i need one becuase i added the 80mm tb 85 mm intake headers, and i got nos soo im tryin to get down to the dyno. How long will it take for the car to adjust? I forgot to add ijust unpluged my rear o2s for now
Old Feb 25, 2007 | 07:32 PM
presto_z's Avatar
i was running really lean after my header and ory install
Old Feb 25, 2007 | 07:33 PM
should i just bolt all my mods on and wait to drive seein its like 15 degrees with 3 feets of snow here, till imake it to the dyno? Or will it not hurt on dry road days to putt around
Old Feb 25, 2007 | 08:05 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I did headers and cam at the same time and ran tuneless for the better part of a year. No difference that I could tell, but it was just a numbers game in the end. Not the biggest cam in the world either. 224.
Old Feb 25, 2007 | 08:09 PM
so as far as my egr and air goes i have the block offs all on and unplugged it all so now i can take the pump out near the fog like right?
Old Feb 25, 2007 | 09:29 PM
JL8Jeff's Avatar
Sounds like you have another issue like a cracked plug, intake leak or something else. Headers and ORY will not make it run much different than stock so look for something else that is messing up the computer.
Old Feb 26, 2007 | 02:57 PM
there brand new plugs and wires
Old Feb 26, 2007 | 03:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Doesnt mean that they are perfect.
Old Feb 26, 2007 | 08:28 PM
it runs ok i thought i could hear poping but its the f-ing y pipe bangin on my floor boards lol, but it runs some what like it could be rich, i put the tb on tonight, how do you adjuct your throttle cable when my pedal is wot the butterfly has like 1/4 or less to go till its wot
Old Feb 26, 2007 | 10:11 PM
RrCoX22's Avatar
the bumb stop mod is your friend
Old Feb 27, 2007 | 11:06 AM
haha well i hope it comes around as far as the pcu picking up the new mods and chaging since i unpluged stff till i get a tune
Old Feb 27, 2007 | 11:14 AM
Hennytime's Avatar
not much changed from installign the macs/ory i was around 12.1 A/F ratio on the dyno and then a couple days ago, my buddy logged it with the LM1 and the leanest it got was 12.4 A/F the midrange is a beast now. Ill wait to get hte car tuned until the cam gets in though
Old Feb 27, 2007 | 07:26 PM
see i unplugged my rear o2s so oim not sure if they is making it worse?
Old Feb 28, 2007 | 03:33 PM
matt94z's Avatar
I was really lean when I got my headers on. Right at 15.1.
Old Feb 28, 2007 | 05:28 PM
well i was going to go saturday to new era performance but the looks of the weather im not gonan be im upstate ny at the tippy top and its bad some days here! I took it out tonight for 20 miles or soo and its rough, would unplugging the egr air and rear o2s make it worse ?
